[POLL] Choose Most Fastest, Low Resistance 100PSI < tires out the 13 set
10/13/2021 2:21 PM
Need help choosing a set of tires boys, the fastest ones, don't care for tricks, need speed. Most low resistant to friction and ones that roll for miles with a 28t sprocket. Fast fast fast.
1. Wethepeople Activate 100 PSI 20" BMX Tire
https://www.skatepro.com/en-us/374-42898.htm
2. Sunday Streetsweeper 20'' BMX Tire 100 PSI
https://www.skatepro.com/en-us/374-27235.htm?stockcode=SUN-TR-STSW-RED
3. Shadow Contender Welterweight 20" BMX Tire 110 PSI
https://www.skatepro.com/en-us/374-33791.htm
4. Subrosa Designer 20" BMX Tire 110 PSI
https://www.skatepro.com/en-us/374-41985.htm?stockcode=SUBDSGNTI240-RED/BLK
5. Total BMX Killabee 20" BMX Tire 110 PSI
https://www.skatepro.com/en-us/374-31522.htm
6. Demolition Momentum 20" BMX Tire 110 PSI
https://www.skatepro.com/en-us/374-38925.htm
7. Eclat Decoder High Pressure 20" BMX Tire 110 PSI (Eclat staff confirmed these to be their fastest tires)
https://www.skatepro.com/en-us/374-32898.htm
8. Shadow Creeper 20" BMX Tire 110 PSI
https://www.skatepro.com/en-us/374-41969.htm?stockcode=SCCREEPTI240-FIN
9. Shadow Serpent 20" BMX Tire 110 PSI
https://www.skatepro.com/en-us/374-39452.htm
10. MAXXIS GRIFTER STREET TIRE (BLACK) (2.4") (20" / 406 ISO) (FOLDING) (DUAL)
https://www.danscomp.com/maxxis-grifter-street-tire-black-2.4-20-406-iso-tb00360700/p-5uqvsauqbbacqage?v=1262356
11. FIT BIKE CO FAF TIRE (BLACK) (2.4") (20" / 406 ISO)
https://www.danscomp.com/fit-bike-co-faf-tire-black-2.4-20-406-iso-32-twb-blk-240/p-5uqchzkquc2cqage?v=1073999
12. Tioga Streetblock 100 PSI
https://www.tiogausa.com/street-block.html
13. BSD ALEX D DONNASQUEAK TIRE 110 PSI
https://us.sourcebmx.com/products/bsd-alex-d-donnasqueak-tyre?variant=25814762750016¤cy=usd
Fastest most rolling low resistance tires. What to get.
View Results
10/13/2021 2:42 PM
Primo Champ 20 x 1.0. Ultimate pizza cutter mode to reduce rolling resistance as much as possible.
10/13/2021 5:43 PM
Animal-T-1 tire you can look at as well.
10/13/2021 10:28 PM
Just go for any tire with a smooth or unbroken middle tread. You are the engine and power source for the bike, the person riding it determines speed. The way you turn, carve, and manipulate the bike leads to speed, not 100% dependent on a tire. Also, consider gear ratios, that changes a lot of things.
10/14/2021 5:08 AM
Edited Date/Time: 10/14/2021 5:10 AM
fit faf 2.25 holds 125 psi for months.
try 30t sprocket
edit* do we apply physics here?
lighter tires vs heavier tires
tire height/width
10/14/2021 6:36 AM
The demo momentum has a smooth simple tread. It is very grippy, can hold high PSI, but one big catch is that the rubber compound is super soft. This means that is easily get cut when riding street (bits of glass, thorns, sharp rocks, etc.). The soft compound makes it ultra grippy though, so it is a trade off. Great tires for primarily riding park. Plus, they are very light (I believe one of the lightest non-folding tires). Being that they are light, they are lightning quick.
As said above, other important factors for speed are tire width (skinner = faster)
Gear ratio, (higher means higher tip speed)
Wheel bearings, etc.
10/14/2021 9:34 AM
When I rode Fit T/A’s those things rolled smooth as hell
10/15/2021 12:58 AM
readybmxer wrote:
Just go for any tire with a smooth or unbroken middle tread. You are the engine and power source for the bike, the person ...more
This. Don't sleep on odysey path pros smooth center line, really good rolling resistance performance
