Pegs
1/7/2014 6:35 PM
What size pegs are generally for front and rear? Is it 3/8 in the front and 14mm rear? Also whatever size it may be, will they be compatible with the daily grind front hub? (It has a 15mm center axle)
-HardBMX_Tim
1/7/2014 6:38 PM
3/8" front, 14mm rear.
the Daily Grind hub uses 3/8" bolts, that thread into the 15mm center axle. The bolts are what determine what size pegs you would need, which in this case is 3/8"
1/7/2014 6:39 PM
the Daily Grind hub uses 3/8" bolts, that thread into the 15mm center axle. The bolts are what ...more
Ohh alright man, I wasn't thinking clearly. Thanks
-HardBMX_Tim
1/7/2014 6:40 PM
3/8s front. The center of the axle doesn't matter at all. The female bolts that go into the hub and more importantly on this subject hold the peg on are 3/8s. 14mm rear almost always. Unless you have a shemale hub (3/8s bolts, 14mm center axle with nub for dropouts)
For the length of the peg i usually like a longer peg up front because it helps to get locked into smiths and anything involving the front peg. Usually like 4.5ish. i like 4 inch pegs for the rear because i dont get so worried if i mess up a wallride.
1/7/2014 6:58 PM
exactly what maximus said
Old bike VVV
California Living
1/7/2014 7:02 PM
I never realize. 14mm pegs are for the size of the axle , not the bolts? I used you to think they wouldn't fit on 17mm bolts haha.
