Polished
9/28/2013 6:23 PM
So I'm in the process of rawing my frame but If I had more money I would get it chromed. My friend told me that if you polish the frame with car polish before you clear coat it that it will look almost like chrome. Has anyone had expirence with this?
My Fit
9/28/2013 6:59 PM
You can do this, through gauging down Different grits of sandpaper and then buffing it, however, it will rust just like a regular raw frame. Chrome doesn't rust as easily as steel, which is why steel things are chromed and aluminum things are polished (different grits then buffed) because aluminum takes ages to rust, so it doesn't need the chrome finish to stay fresh.
9/28/2013 7:06 PM
You can try it. The big issue is that paint: aka clear coat, will not stick well to something that is
A) Not scuff sanded
cool Not primed.
Factory clear doesn't stick either. It's a gimmick. A fad. A trend. The companies aren't trying to make their frames corrosion resistant. They just want to sell more frames.
9/28/2013 11:32 PM
So if i just use find grit sand paper to get a better finish the clear coat will stick better?
My Fit
9/29/2013 2:03 AM
What grit should be used to get a polished look
9/29/2013 2:04 AM
9/29/2013 2:07 AM
Idk Wtf just happened
9/29/2013 5:20 AM
All of them lol. You start with a rough sand paper, and then go down slowly to smoother ones. You should probably use atleast 8 different grits, and then buff it. If done right, it will have that chrome shine. And if you get a clear finish powdercoated on it will stick, but over time, the steel is still going to rust (a lot faster than chrome)
9/29/2013 3:03 PM
Edited Date/Time: 9/29/2013 3:04 PM
HardBMX_Tim wrote:
All of them lol. You start with a rough sand paper, and then go down slowly to smoother ones. You should probably use atleast ...more
What do you mean buff? Isn't that pretty much the same as putting polish on it? I've never done much more than spray paint something so this is all new to me lol.
My Fit
9/29/2013 3:53 PM
fitbikerider14 wrote:
What do you mean buff? Isn't that pretty much the same as putting polish on it? I've never done much more than spray paint ...more
Buffing removes the scratching/blemishes from sanding, however it only gives that chrome look when done after a very fine grit paper. Polish is just used to give something an artificial shine I BELIEVE.
9/29/2013 4:05 PM
oops didnt mean to quote this... but anyway dont put any clear coat and then just make sure to buff it often and it will stay shiny..
Deviant BMX store
9/30/2013 5:04 PM
Ok thanks guys.
My Fit
9/30/2013 5:14 PM
Chrome/Polished is ugly.
9/30/2013 5:16 PM
Yes... This^
ı̸̸̸̸̸̸̸̸̸̸̸̸̸̸̸̸̨
9/30/2013 5:25 PM
Chrisaustin wrote:
Yes... This^
I'd say you're pretty fucking lucky that it's not your bike then, huh!?
Carry on.
9/30/2013 7:32 PM
HardBMX_Tim wrote:
You can do this, through gauging down Different grits of sandpaper and then buffing it, however, it will rust just like a ...more
Actually Aluminum's corrosion is a crusty white film, and it starts corroding INSTANTLY.
Steel takes longer to see the corrosion. Chrome is usually plated or dipped, and will not corrode nearly as fast, as it has to typically flake off or get damaged so corrosion builds up behind it.
BUT, polishing your frame would get it pretty shiny, but not the mirror like finish chrome will give.
9/30/2013 7:56 PM
Edited Date/Time: 9/30/2013 8:01 PM
Latest edit (Check it out) | Anything With Two Wheels Goes!!
"Fuck it and Huck it" -Tomdon
9/30/2013 7:58 PM
This perfectly explains how to do it. Use polishing compound when you buff it and you will get a near chrome result
9/30/2013 7:59 PM
Sharpy wrote:
I didnt exactly make it clear. The actual polish look comes from a polishing wheel. You do need to sand it first but the sanding will not polish it by itself.
9/30/2013 8:07 PM
Sharpy wrote:
I didnt exactly make it clear. The actual polish look comes from a polishing wheel. You do need to sand it first but the ...more
I love how you edited your comment.Photo
9/30/2013 8:42 PM
I think I'm actually just gonna get some metallic silver rustolium and be a little different from everyone's raw frame and this way I shouldn't have to worry about rust if I do it right.
My Fit
9/30/2013 8:46 PM
Edited Date/Time: 9/30/2013 8:47 PM
I think I'm actually just gonna get some metallic silver rustolium and be a little different from everyone's raw frame and ...more
I looked it up, i think it would look okay. but its not much different to silver spray paint. I think polished would be much better.
9/30/2013 8:46 PM
It won't look anything like chrome. Just headsup. Maybe look into getting it nickel plated/dipped? I think it might be cheaper. Looks damn near the same
9/30/2013 8:51 PM
Edited Date/Time: 9/30/2013 8:52 PM
If I can get a color a little darker than this then I think it will look pretty sick.
Edit: hopefully the metallic paint is a little shiner too
My Fit
9/30/2013 8:53 PM
HardBMX_Tim wrote:
It won't look anything like chrome. Just headsup. Maybe look into getting it nickel plated/dipped? I think it might be ...more
It would be cheaper than buying primer and spray paint?
My Fit
10/1/2013 4:34 AM
I doubt it. I honestly don't know much about it. Research it! And yeah a friend of mine had his bike that silver color and it was killer! Just get matte silver paint and matte clearcoat.
10/1/2013 7:24 AM
HardBMX_Tim wrote:
I doubt it. I honestly don't know much about it. Research it! And yeah a friend of mine had his bike that silver color and it ...more
Alright I'm probably gonna get spray paint like Wednesday so when I finish it I'll post some pics since I got a new phone that takes awesome pictures smile
My Fit
10/2/2013 6:20 PM
Shes primed and ready for paint in like half an hour smile I managed to find some chrome spray paint that looks pretty sick cant wait!
My Fit
10/3/2013 1:19 AM
fitbikerider14 wrote: Photo
Shes primed and ready for paint in like half an hour smile I managed to find some chrome spray paint that looks pretty sick cant ...more
Have you got a final photo?
10/3/2013 9:05 AM
Still needs another coat of paint and some clear coat but this is what it looks like.
My Fit
