So when I go to ride my bike , it makes a popping sound. Further inspection , it seems specifically at a CERTAIN point ; when my back pedal is alighned with my chainstays. It's the same side as my freecoaster. So when I pedal at that exact spot it makes a click / pop sound. The chain tightens somewhat but not much. It also makes my cranks pop forward too when you apply pressure. It seems stuck but you pedal and it ... skips?
I'm thinking it might be a part of my coaster that needs grease , although I used a fair amount when I did grease it. The hub is relatively new , maybe an hour and a half total ride time (trying , not cruising). Or my sprocket might be bent even though it's basically never ridden...
Help ! I'll take my coaster apart and grease it , as it still might just be breaking in but it shouldn't be like that. My chain is greased and my sprocket seems fine. The crank bolts are tight and no play is in the cranks.
