Primo Axle on Cult Match?
7/31/2013 3:20 PM
From what I know, the my Cult Match hub has the exact same internals as the Primo Mix.
I've stripped my axle on one side on my current Match axle, so I need a replacement.
Does anyone know for sure if I could use a Male Primo Mix axle such as this one?
http://www.danscomp.com/products/439017/Primo_Chromoly_Axle.html
Or even use the Female conversion kit which is also one of the options in the link above.
Thanks a lot!
Email: mccheesekid@gmail.com
Instagram: @McCheeseKid
Bought from: hrin, Me?, ecuadevil, regalracing, Dolphin
7/31/2013 3:34 PM
I know this is out of your topic, but how you like your cult match? I'm pretty sure you could use that axle, its a mix just rebranded
Text For Faster Response (727) 218 4305
Follow Me On Instagram - @Marcog_727
Refs–
Sold : Mrhavoc1988, Skubasteve, Joe_Martinez, -Havok-
Bought : ii Krxfted, Tomdon, SnM An1mal, ScramHype, Ecuadevil, TheHorrorContract
Traded : Wolfen, Kevin_Burnett, The_Bmxist, Wilberto_Mora, Mobking, Joe_Martinez
7/31/2013 3:36 PM
99.9% chance it will
Put in work.
Put in work.
Put in work.
Flacko put 'em in the dirt.
1/16/2015 8:59 AM
Really sorry for bumping this thread but id rather do that than make a new one. Will primo axles work in a cult match hub???
1/16/2015 9:07 AM
Primo Mix axles will work, Remix won't. Front won't fit at all.
1/16/2015 10:21 AM
This. Remix is 15mm internal and Mix/Match are 14mm internal.
1/16/2015 2:50 PM
No, they're all the same at 14mm & 15mm on the non-drive side where the hardware threads on, the difference is the Remix uses different bearings so the bearing contacts on the axle is different from the Mix/Match
But as said, Primo Mix axles will fit the Cult Match & vice versa, but Primo Remix will not.
1/16/2015 4:45 PM
sundaybmxRR wrote:
No, they're all the same at 14mm & 15mm on the non-drive side where the hardware threads on, the difference is the Remix ...more
Then why does the Animal PYN work with the Mix and not the Remix?
1/16/2015 5:02 PM
Was it drilled/rethreaded? Because without being modified, there isn't anyway the PYN should work on the Mix at all, the area where the hardware threads onto that side is 15mm
You can see it here
I've had all 3 hubs (Mix, Match & Remix) and they're all like that, only difference in them being the Remix is more hollow & the bearing contacts are shorter.
I even have the Match & Remix in my room right now and can verify the 15mm if you still don't believe me haha.
1/16/2015 5:06 PM
I was looking for a guard for my remix and read on an old thread that the PYN fits the Mix so i went with it and it didn't fit. Assumed the Remix was different than the Mix.
1/16/2015 5:15 PM
HardBMX_Tim wrote:
I was looking for a guard for my remix and read on an old thread that the PYN fits the Mix so i went with it and it didn't ...more
I remember someone on here modified their PYN that it would fit a Mix, so maybe that's what you read?
Cause the PYN rear guard & the Animal Javelin axle are both 14mm, so there's no way it could fit
1/16/2015 5:18 PM
Cause the PYN rear ...more
That was me. I modded my pyn for the remix when i found out it didn't fit.
1/17/2015 7:00 AM
Remix is a garbage hub shouldn't have ever made it into production
Testimony and apologies
instagram
old edit
1/20/2015 1:15 AM
The only thing I hate is how some hubs are made with different flange sizes. It seriously pisses me off to have to get 2 sets of different spokes, let alone happening to only have one set and end up with longer spokes. That's how my Gsport hub was and I ended up having to run some of the spokes like 1-2mm longer, so I had to run like almost 3 rimstrips.
1/20/2015 6:04 AM
isnowyaznV2 wrote:
The only thing I hate is how some hubs are made with different flange sizes. It seriously pisses me off to have to get 2 sets ...more
I totally agree, its is completely retarded to have different size flanges, profile hubs use to be awesome when i first starded riding and now they are the gayest hubs on the market because they started that dumb ass flange trendy garbage weight weenie nonsense
instagram
old edit
1/20/2015 6:56 AM
I totally agree, its is completely retarded to have different size flanges, profile hubs use to be awesome when i first ...more
Shouldnt it techmically weigh less with larger flanges? Lets say 2mm on each spoke. Thats 72mm of steel instead of having bigger flanges. So losing 72mm of steel and adding a little bit of alluminum, is more efficient in terms of weight. But less steel means less strength. Smaller hubshells, and smaller but still THICK flanges would be the best. So their new smaller flange design is technically heavier and stronger. I think it was a good change asthetically too.
1/20/2015 6:57 AM
When I say heavier I dont mean the shell. Im saying when the wheel is built up.
1/20/2015 8:55 AM
StoreBoughtChild wrote:
Shouldnt it techmically weigh less with larger flanges? Lets say 2mm on each spoke. Thats 72mm of steel instead of having ...more
Larger diameter flanges = stiffer wheel, easier to damage, heavier (there's a lot more material used to add to the flange than there is to add to the spoke, however flange weight will be less noticeable than spoke weight, so in a way you are right.)
Different diameter flanges = improper spoke tension, wheel wants to pull to one side more than the other. Think of it like guitar strings. As you shorten the string (spoke) by moving your hand (hub flange) closer to the base of the guitar (rim), the sound produced (spoke tension) changes.
Shorter flanges = less stiff wheel, harder to damage, lighter.
