Primo Churchill cranks... come with crank tool??
6/30/2018 8:08 PM
Just wondering if the Churchill cranks come with a crank tool? None of the promo material i can find shows a tool. Just the cranks and BB.
Thanks!
6/30/2018 8:56 PM
I think most all cranks come with them regardless of if they say they do
7/1/2018 6:58 AM
I have bought and owned many different cranks from primo, Odyssey, cult... never have I received even an Allen wrench let alone a crank tool... never seen a crank tool come with cranks.
7/1/2018 10:09 AM
1138thx wrote:
I have bought and owned many different cranks from primo, Odyssey, cult... never have I received even an Allen wrench let ...more
My profiles came with one
Hmmm
7/1/2018 10:15 AM
Profile cranks do, many don’t. But, a little trick is to take the spindle and crank bolt to the hardware store. Get a bolt about 1/4th to 1/2 inch longer than the one that comes with it and 2-3 washes. The washers need to be bigger than the opening of the crank arm. Now just line everything up, add some grease and inserted the longer bolt. Use it to get the arm started on the spindle. Once both are on 1/4 or so. Use the normal bolt that the cranks came with to get everything set up and even. Works EVERY time
7/1/2018 12:33 PM
I straight smothered the Compression bolt with grease and very slowly torqued the cranks on with an Allen socket for my Calibur Cranks. (Before I had to buy the tool for it separately of course)
7/1/2018 8:29 PM
Phunny93 wrote:
I straight smothered the Compression bolt with grease and very slowly torqued the cranks on with an Allen socket for my ...more
That can work I just make my own tool just in case the bolt snapped I can easily get it out ??
