I have both, but can't decide which one I'd rather use. I've been using the V3 for the last month or so, but switched to the Mix after I got it over the weekend just to try it out since I had a Primo hub before the V3 and it was great. I've built my bike with almost all Odyssey parts because I know their stuff is legit, and I like the look of a low flange V3 hub alot more because the Mix is ugly imo. I also have a Hazard V2 front hub, so the V3 rear does look alot closer to matching with it compared to the Mix (and is also the same color, the Mix isn't). But tbh, I trust the driver/pawl system on the Mix alot more since the driver on the V3 wiggles a bit even when tightened all the way down, and only has 3 pawls with a ring, where as the Mix driver is flush and tight and has 4 pawls on individual springs. Both have pros and cons, so if these were your only choices for a rear hub, which one would you run and why? And I run my hubs completely caked in grease for silence, so I don't want to hear any "Mix because it's louder" bs. Lol
