Primo Remix v2 cassette hub
1/13/2016 9:16 PM
A couple years ago it was rumored, but now it seems it's finally out for anyone interested in it
https://www.danscomp.com/products/426199/Primo_Remix_V2_FA_Cassette_Hub.html
Revised hub shell (Probably cause people were actually snapping the Remix v1's hub shell due to how skinny it was...)
Features:
-17mm chromoly center axle with 14mm chromoly bolts
-Hopefully the same Mix driver, all it says is "1-pc chromoly driver with bushing for reliability and needle thrust bearing to reduce drag" so I'm not sure if that'll use the same style driver or not.
-4 individually sprung pawls (Same as the Mix)
-Size 17287 bearings in the hub shell, Danscomp says it uses 2 of them, but the previous Remix & Mix hubs all used 4 bearings, so we'll see. Although just 2 is more than a good upgrade from the 4 tiny 6802 bearings the Remix used though.
-Includes guards(plastic ones), and weighs in at 18.7oz total, guards included.
-Comes in at $144.95, which is a bit much compared to what they used to cost ($119.99)
1/13/2016 10:17 PM
Noiiicee. Too bad I switched to coaster.. sad face
1/13/2016 11:12 PM
I'll probably get that and a N4FL when the time comes for wheel replacements, my Wasps are holding steady at the moment.
My Youtube / RainBMX
My Insta / What_Is_Barspin
