Problem with Odyssey Director Forks
2/23/2018 9:23 PM
Bolted the forks down w/ the compression cap and the bars won't even turn - its like it's really stiff. Any reason to that? Do I need another spacer or something?
2/23/2018 9:42 PM
Your headset spacer is probably rubbing on your frame. Put a small, 1mm spacer under the head set cap.
2/23/2018 10:51 PM
Headsets usually come with a thin silver spacer that goes under the cap. If you don't have one, file the cap down a bit on the bottom
2/23/2018 11:12 PM
When you turn the bars, is the headset cap supposed to turn w/ the bars/forks/stem as well? Cause the cap is literally right on the frame.
2/23/2018 11:29 PM
Raffy wrote:
When you turn the bars, is the headset cap supposed to turn w/ the bars/forks/stem as well? Cause the cap is literally right ...more
Yes. Put a thin spacer under it.
2/23/2018 11:36 PM
Where can I get one?
2/24/2018 12:02 AM
I'd first call your local bike shop and ask if they have any 1mm 1-1/8th headset spacers, or you can get them from ebay for 2.95 shipped, or pretty much any online bike store.
2/24/2018 7:20 AM
Bryan91 wrote:
I'd first call your local bike shop and ask if they have any 1mm 1-1/8th headset spacers, or you can get them from ebay for ...more
This. You may even need two of them.
2/24/2018 7:42 AM
1mm will be more than enough. Providing the headset has been put together properly
2/24/2018 7:45 AM
Mine needed two on my Mothership X BSD headset. I had another set up once that did too, don't remember which. All depends on the headset cap/frame.
2/24/2018 12:57 PM
HardBMX_Tim wrote:
Mine needed two on my Mothership X BSD headset. I had another set up once that did too, don't remember which. All depends on ...more
You seem to love disagreeing with me. All I can say is that must be pretty poorly manufactured frame if you need 2mm of spacers under the headset cap. I've never once needed any more than the silver spacer that comes with headsets
2/24/2018 1:06 PM
You seem to love disagreeing with me. All I can say is that must be pretty poorly manufactured frame if you need 2mm of ...more
Lol I only speak from experience.
Sure, maybe I've ended up with poorly manufactured stuff twice, or maybe some parts are just made differently from others. Couldn't tell you what it is tbh, but fact of the matter is that sometimes two is necessary.
2/24/2018 1:32 PM
Maybe in your experience. But 10 or so frames with integrated headsets of my own, and over 15 years as a bike mechanic, I've never seen it.
2/24/2018 1:38 PM
Ditch the headset cap
2/24/2018 1:42 PM
Yeah headset caps are too heavy anyways...
2/24/2018 2:03 PM
Headset cap, compression ring, blown bearing, bearing inner race could be unseated. Top cap might be too tight. Thats all i can think of at the moment.
2/24/2018 2:08 PM
Maybe in your experience. But 10 or so frames with integrated headsets of my own, and over 15 years as a bike mechanic, I've ...more
I'm not saying that you have. Just saying that if it can happen to me twice in the course of 10 or so bikes, it can certainly happen to the OP. In fact, for all we know, he already has one in there and just needs another. Who's to say but OP himself?
As I said in my original comment, You may even need two. Not that every bike will need two. Calm ya tits.dizzy
2/24/2018 2:11 PM
HardBMX_Tim wrote:
I'm not saying that you have. Just saying that if it can happen to me twice in the course of 10 or so bikes, it can certainly ...more
I use 2 on mine so it's just flush with the frame but I've been using the same compression ring since my first integrated headset and it's a little worn.
2/24/2018 2:33 PM
p1p1092 wrote:
I use 2 on mine so it's just flush with the frame but I've been using the same compression ring since my first integrated ...more
Which very well could be the case for OP too.. Just pointing out possibilities and trying to help. Not sure why some feel the need to get so defensive about it.
