Profile "peg" bolt step not enough
12/15/2020 1:57 PM
The peg bolt on the profile female bolts have a longer 14mm step on the beginning to fit pegs. Seems to be way too short. is it safe to run like this or should i drill out/change my peg?
bikes
12/15/2020 2:01 PM
Your playing a game of Russian roulette
12/15/2020 2:13 PM
That isn't tightened down all the way so it might go in another mm or two. Also, the mini was 108mm wide while the frame is 112 so there's a sizable gap, and I don't know if a hubguard will fix the issue
bikes
12/15/2020 2:29 PM
Tighten it down first and then post a pic.
You don’t want it to go all the way to the hub, that would prevent it from tightening down.
12/15/2020 3:49 PM
Edited Date/Time: 12/15/2020 3:50 PM
tightened down: Photo
Around halfway through.
I was thinking taking off a tiny bit of material from the inside of the peg
bikes
12/15/2020 4:02 PM
Just get these and you're golden.
https://www.luxbmx.com/kink-10-14mm-axle-adapter
Obviously look for them at places around you.
