Proflie Mini Hub Axel Conversion Kits?
4/26/2013 9:27 PM
Does anyone know how the axel bolts that just screw in to your hub work? and can you ride pegs with them?
I want to build new wheels and I wanted to see if I could get blue six ti bolts, like the kind that just screw in. This probably sounds Somebody told me I need an axle conversion kit, but I dont know wtf that is and what kind to get.
Please Help!!
RIDE! - FBG$
4/26/2013 9:32 PM
Edited Date/Time: 4/26/2013 9:37 PM
what hub? front or rear I mean
4/26/2013 9:51 PM
Rear
RIDE! - FBG$
4/26/2013 9:53 PM
Im basically asking how the axel bolts that look like they screw into the axel look and what kind of axel I would need to get these for a profile mini hub
RIDE! - FBG$
4/26/2013 10:01 PM
That would be female axles...? Those are screw in. Don't grind a mini bro.
4/26/2013 10:06 PM
bmflexxer wrote:
Im basically asking how the axel bolts that look like they screw into the axel look and what kind of axel I would need to get ...more
Are you trying to convert your 14mm hub to 3/8 female? just making sure.
like you want it to look like this
but right now it looks like this?
or do you just need the bolts? I'm kind of confused.
4/26/2013 10:08 PM
dont run pegs on a mini?
RIDE! - FBG$
4/26/2013 10:11 PM
I wouldn't. They're making some hubguards for it but mini's are expensive and good.....if you grind alot, get a demolition or something. Plus female axles aren't great for grinding on.
4/26/2013 10:27 PM
Edited Date/Time: 4/26/2013 10:27 PM
I wouldn't. They're making some hubguards for it but mini's are expensive and good.....if you grind alot, get a demolition or ...more
Female Axles are actually very strong for Grinding. The problem is that there needs to be an Axle bigger than the Bolts, which means smaller Bearings or an overall larger Hub, hence why most Female Axles have 3/8" Bolts instead of 14mm ones. The 3/8" Bolts are much better than a 3/8" Axle. The 14mm Female Bolts that come with, G-Sport Ratchets, Odyssey Antigrams, Shadow BTRs and Tree Rears are really strong.
