Pump Broke
3/27/2017 8:52 AM
Pumping up my tires and this happens , ended up finding a split / crack in the hose near the end and when I went to go investigate it , fell right off . I've had it for like 3-4 years maybe ? I've taken great care of it , has anyone else had this happen to them . It was a pretty expensive pump .
I can grab another one from work for cheap , any advice for new ones ?
3/27/2017 9:10 AM
Can you unscrew the bottom and just remove the broken piece of tube? Mine unscrews as mentioned. I've had to remove cracked bits before.
3/27/2017 12:16 PM
Yep, as said it should unscrew then you just slide the unscrewed part over tube, then attach to the valve adaptor and screw it back up
