Putting Grips On...
5/25/2009 5:05 PM
Basically i've just got a set of volume la grips and have managed, after much struggle, to remove the old grip and put the new one one. Surely there must be an easier way than just pulling them, or cutting them off then slowing sliding the new grip on?
5/25/2009 5:06 PM
spray a little bit of hairspray into them, and then slip them in
My nigga Ressler, stay up!
My nigga Babysatan, stay up!
My nigga Copiolet, stay up!
My nigga DakAttack, stay up!
My nigga NCDave, stay up!
My nigga Enzo, stay up!
And I ride for my niggas
5/25/2009 5:09 PM
wd-40 works to put em on
massholes 4 lyfe!
bstick
legendsx23
5/25/2009 5:10 PM
wd-40 takes a while to dry, a very long while. if ur gonna use wd-40 ur better off spiting into ur grips.
5/25/2009 5:14 PM
thanks guys smile
5/25/2009 5:14 PM
anytime
5/25/2009 5:18 PM
yah anytype of lubircant..but hairspray is great it dries sticky
team fatcats fer life.
5/25/2009 5:37 PM
i use vinegar cuz its all natural and i care about the environment ;p
BMX riding Cop... Let that sink in for a minute.
5/25/2009 5:38 PM
no it doesnt i put mine on and use them right away
massholes 4 lyfe!
bstick
legendsx23
5/25/2009 5:39 PM
every time i've used wd40, my grips dont last cuz it eats through them. fuck that shit. i dont use it on anything on my bike ever.
5/25/2009 5:40 PM
use whatever u want
5/25/2009 5:43 PM
Where'd you find them?
WILBERT HERNANDEZ...
5/25/2009 5:49 PM
i work in a bike shop and the hairspray and wd-40 work but the grips move. we use a air compressor. 30 secs both grips are on and they don't have any movement once on.
Just Say Fuck It And Go For It
5/25/2009 5:50 PM
thts the best easyes and least messy way 2 do it
5/25/2009 6:15 PM
WD-40. Dissapates moisture, prevents slippage when cured.
5/25/2009 6:33 PM
AIR COMPRESSOR
On My bicycle i have the freedom to do anything i put my mind to, and thats what i live for
5/25/2009 6:42 PM
Yea but not everyone has access to an air compressor. Use the zip tie trick shown on RideBMX. You simply slip some long enough zip ties in your grips, slide your grips onto your bars,and then pull the sip ties out.
I've never tried it but I probably will next time.
This message is brought to you by JonathanAllen.
This is Red Panda.
http://en.wikipedia.org/wiki/Red_panda
MOTW 5/17/2010 - 5/23/2010
5/25/2009 6:48 PM
I always use an aircompressor if you don't have on go ask a friend or go to a local bike shop
Well,what have we here...apparently....Idk what we have here. sad
5/25/2009 8:01 PM
baby oil
Yeah
5/25/2009 8:44 PM
when taking them off cut them with a razor blade but when putting them on use an air compressor
5/25/2009 9:11 PM
i just put some water under them when i take them off. then either muscle the new ones on, or use an aircompressor. hairspray works as a lube then makes it stick.
(\__/)
( .Y. )
(")v(")
09 Kink Transition...yes...i ride a tranny.
Im the CLIT commander of the sexy army.
5/26/2009 1:03 PM
hairspray works amazingly the alcohol in the hairspray will evaporate and basically turn it to glue
5/26/2009 1:07 PM
i use rubbing alcohol, cheap and it takes less time 2 dry the hairspray
5/26/2009 1:13 PM
icut my old ones off and use aclaholic hairspray or an air compressoer 2 put them on
I got refs
5/26/2009 1:15 PM
how r the grips im gettin them soon what r they like?
I got refs
5/26/2009 1:41 PM
where did u got those LA grips man
5/26/2009 1:49 PM
check UK sites they all sell them
I got refs
5/26/2009 3:01 PM
Cutting them off is probably the fastest and easiest way to take grips off, but i've tried using zip ties to put them on and it works fine.
