Rear wheel help
4/4/2017 6:18 PM
I've tightened my wheel to the point that I was standing on the wrench(I'm like 150lbs). The wheel would start off being in line and the chain tight. But when I take a few cranks then the wheel goes out of line and the chain becomes loose
4/4/2017 6:23 PM
That's how you destroy bikes man.
4/4/2017 6:30 PM
Edited Date/Time: 4/4/2017 6:30 PM
Don't stand on wrenches smile jumping is even worse :D
I hate that but if you don't have chain tensioners buy them. Few bucks,not more.
Till then don't kill your bike but put something like a small bolt or whatever to fill the space between bot dropouts and hub. I can't express myself very good (not my native language).
4/4/2017 6:40 PM
on both side put the same width piece of hard rubber,nut or something. Not very desirable hack but it can hold a few days while chain tensioner arrives in your mail.
4/4/2017 6:44 PM
There,photoshop saves my bad english. smile It worked for me,I did that all the time. But again,be careful not to damage
bolt threads with whatever you put in.
4/4/2017 7:47 PM
bolt ...more
thanks for the help ill try
4/4/2017 9:31 PM
Are you using a washer between your dropout & axle nut/bolt? If not, there's your problem. Put one on and try, it should fix it. If not, then it could be something worse like a bent dropout or axle.
4/4/2017 9:57 PM
Just tighten one side at a time and push each side back a little each time
Dax in NYC
MD & Flatland rider
