Redline Syntax 21" 2013 - Opinions?
5/4/2016 3:27 PM
What's up?
I'm thinking about buying the redline syntax 2013 but I wanted to know what you think about it or about redline in general.
I'm 1,83m / 6ft tall and I'm this is going to be my first bmx bike.
Specs:
Wheelset 36 Hole
Front Rim Alienation PBR - 36H
Rear Rim Alienation Blacksheep double wall - 36H
Front Hub Redline Alloy with 3/8" Axle - H
Rear Hub Redline semi-sealed alloy cassette with 14mm axle
Spokes Black
Front Tire Odyssey Aitkin 20 x 2.25"
Rear Tire Dirt Path 2.2"
Frameset
Available Frame Sizes 21"
Frame Full 4130 chromoly main triangle with integrated headtube, integrated seat tube collar, removable brake hardware and Mid BB
Frame Material
Chromoly
Fork Monster tapered leg with 1-1/8" chromoly steerer
Headset 1-1/8" Integrated - Campy standard
Stem Redline Hollowpoint with M8 bolts - L56mm
Drivetrain
Crankset 100% heat treated tubular chromoly 3 piece - 175mm
Chainring (chainwheel) Anodized black aluminum - 25T
Driver 9T chromoly sealed bearing Driver
Bottom Bracket Mid BB with sealed bearings
Pedals Odyssey Twisted PC - 9/16"
Chain KMC Z410
Components
Handlebars Redline 100% Hi-Ten W28.5" with 8.25" rise, 12° Back, 1° Up
Grips Pryme Square Knot withplugs - 143mm
Brakes Tektro FX 340 Rear U-Brake
Brake Levers Textro
Saddle Redline Padded Combo Saddle
Seat Post Alloy
Seat Post Clamp Integrated bolt
Geometry
Seat Post Size 25.4 mm
If this one is not that good which one should I get with a ~300€ / ~400$ budget?
Thanks in advance.
