Removable front brake bosses
3/10/2018 7:44 AM
I know this has been brought up in other posts. But has anyone ever tried to install mounts on a fork to create removable brake bosses on a fork? I have an old fork & was thinking of MAYBE giving it a shot. Since I'm not aware of any manufacturers having tried it, I'm wondering if there's some sort of stress concerns after welding.
3/10/2018 7:50 AM
Deco used to make forks with removable mounts im pretty sure. most steel MTB with V-brakes had removable mounts so i don't see why BMX couldn't.
3/10/2018 7:51 AM
hit up mike laird, he can do it for sure. it's not going to magically make your fork so brittle it brakes after one session.
3/12/2018 8:56 AM
Yeah, I get that it won't "magically make your fork so brittle it breaks after on one session" but I don't want my fork to EVER magically (or non-magically, for that matter) break. Especially if I'm riding it! LOL.
3/12/2018 9:01 AM
Brokenbmx wrote:
Deco used to make forks with removable mounts im pretty sure. most steel MTB with V-brakes had removable mounts so i don't see ...more
Just looked up the Deco fork. They still make it! Interesting.
3/12/2018 9:17 AM
Mishinn_Control wrote:
I know this has been brought up in other posts. But has anyone ever tried to install mounts on a fork to create removable ...more
I w8sh you could just drill and tap them. I have some s&? Forks that had brake lugs welded and they look good
3/12/2018 9:45 AM
Deco did it, they are solid.
If you are iffy on front brakes, try getting an older used fork to check em out, or a brake plate. If you like em then get a fork with mounts?
3/12/2018 10:08 AM
If you are iffy on front brakes, try getting an older used fork to check em out, or a brake ...more
Oh, I'm all over the front brakes. It's just a thought I had & wanted to see what if anyone had seen it done (obviously is has been). It just seems like having the brake bosses available would be t he way to go for a lot of people that like front brakes, but maybe later would want to ditch them, the same way frames have removable brake setups. I suppose it probably comes down to cost. The value added by having removable front brake bosses, it's as valuable as them on a frame.
