Replacement Bolts for Simple Eject V2 Front Hub??!?
2/20/2017 12:54 PM
I just got a simple eject V2 front hub from a friend, and it only has 1 (female) bolt. I was told that the shadow conspiracy raptor front hub and the primo n4fl hub Bolts would work, is this true? And if so, where can I buy replacement bolts? Photo
“Pegless and coaster is ultimate zen”
-Indiana Tom
2/20/2017 1:06 PM
Same axle as the Primo N4FL. The bolts are 3/8"x24TPI, the standard, Very easy to get them, hardware shops should have them or if you want to get something similar to the original: http://www.empirebmx.com/gsport-38-axle-bolt
2/20/2017 2:14 PM
p1p1092 wrote:
Same axle as the Primo N4FL. The bolts are 3/8"x24TPI, the standard, Very easy to get them, hardware shops should have them or ...more
Ok thank you! I'll try my local ace hardware today to see if they have any, and if they don't I'll order some.
-Indiana Tom
2/20/2017 2:23 PM
No problem man, happy to help smile
