Riding low PSI
8/3/2018 5:09 PM
So I ride colony griplock tires, and the max PSI is 110, and I usually ride around 50-60 but whenever I go to a lower psi, the tire comes off the rim in certain spots, and the tube pushes out. Does anyone know how I can stop this from happening so I can ride lower PSI
8/3/2018 5:22 PM
Certain spots of the tyre? Or rim? If you've had a blow out you may have damaged the bead of the tyre, or flared the rim
8/3/2018 5:35 PM
Try running 70-80, usually high inflation tires have a minimum around that psi. You’ll get a pinch flat for running it too low anyways.
-Sheldon on Adam22
"The only future for BMX"
-jbales on mafiaBIKES
-adamnmexican
8/3/2018 7:01 PM
I ride street, 50 odd psi, plenty of bump jumps all day long. Haven't had a pinch flat for years and years
8/3/2018 7:05 PM
Same. I just ride 60 in the back to just to have my manual speed be faster and not slow down too fast... but I've got 50 psi in the front..
8/3/2018 7:07 PM
How much do you weigh though? I can’t run any lower than 80 on my tires without a pinch on bumps, but I weigh around 250 pounds (estimated around 116 kg off the top of my head give or take).
I’m not even fat, I just have dense muscle structure.
-Sheldon on Adam22
-adamnmexican
8/3/2018 7:29 PM
HavokDJ wrote:
How much do you weigh though? I can’t run any lower than 80 on my tires without a pinch on bumps, but I weigh around 250 ...more
I weigh like 130, so 60 and 50 work good for me...
8/3/2018 8:05 PM
Lucky, I weigh two like two jakes lol.
-Sheldon on Adam22
-adamnmexican
8/3/2018 8:24 PM
Lol, you a husky manlaughing
8/3/2018 8:35 PM
I hop into stairsets like a flatbank and ride up stairs if they have 45 degree edges. I also case stuff lol
I run 60psi in my 110psi rated tires.
8/3/2018 11:59 PM
Sounds like you're bead is damaged. I've gone down from 100psi to 70 on slightly bigger tyres. Feels so much better! Any less and flowing around bowls feels sketchy imo.
8/4/2018 12:42 AM
I'm 83kg, recently lost about 5kg. I literally bump jump every curb I ride past when going from spot to spot, and do a lot of bump jump to wall rides etc.
8/4/2018 2:09 PM
I'm 83kg, recently lost about 5kg. I literally bump jump every curb I ride past when going from spot to spot, and do a lot of ...more
That’s still miles below what I weigh lol. Only thing that keeps my hops high is just muscle, weight is definitely not on my side, then again, I don’t have it bad as This Radical dude
-Sheldon on Adam22
-adamnmexican
