Shadow b.t.r hub cone
3/4/2014 5:50 AM
I want to put the shadow b.t.r non drive side hub guard on my b.t.r hub , but first I need to remove the hub cone.. But it seems to be stuck I tryed to pull it out but it doesn't move...
Please helpp
3/4/2014 6:59 AM
Insta: @devicacy
3/4/2014 7:09 AM
Edited Date/Time: 3/4/2014 7:09 AM
^ Nooooo ^
He Means the the Press Fit Cone that comes on the BTR with the TRUE 14mm Female Axle, No Shitty Lock Nuts on that Axle!
Honestly Your best bet is to get a screw driver & VERRRRY carefully push it between the shell & the cone & wiggle it around a little & move around the entire Hub doing this until it loosens up.
OR
If the above doesn't work & this is the slightly more drastic way of doing it! Get Yourself a Towel/Rag & adjustable mole grips. towl over the cone, lock the mole grips onto the cone & move back & forth until You work the Cone off!
3/4/2014 7:19 AM
My bad haha
Insta: @devicacy
3/4/2014 8:12 AM
Topsey wrote:
^ Nooooo ^
He Means the the Press Fit Cone that comes on the BTR with the TRUE 14mm Female Axle, No Shitty Lock Nuts on that ...more
thanks !! helped me a lot !!
