Slipping stem HELP?
5/16/2010 3:19 PM
My stem keeps slipping every 2 or 3 hops that i do. Anyone know how i can fix it or what is a good stem that will not slip?
AUGUST 1ST=GO BMX DAY!
5/16/2010 3:27 PM
um tighten it by doing the x pattern tighten the shit out of the top left bolt and bottom right bolt and do the same to the others.
5/16/2010 3:32 PM
what kind of stem...ody elementary?
team fatcats fer life.
5/16/2010 3:35 PM
fit stem,get a cult stem and then tell us how it is
5/16/2010 3:37 PM
What Bars?You could have bent them to where it doesn't grip right or there not knurled enough.uh otherwise your not tightening the stem enough.Mine is cranked down,if it were to slip i would die for sure
5/16/2010 4:29 PM
its a stock stem and WTP helium bars
5/16/2010 4:31 PM
Throw a new stem on and you should be good then
5/16/2010 4:33 PM
You probably didn't cross tighten the bolts right or that stem just took a fat dump on you.
If you plan on buying a new one inspect you'r bars first. Make sure they are still knurled enough to to grip with the new stem.
5/16/2010 4:34 PM
well theres your problem
Subscribe to me on Youtube.
