Solution to hubs that skip and skipping all together
7/26/2013 8:48 PM
What are some ways to make the hub skip less and have less chance of ever skipping
Albes Is Rad!!!
YouTube
Instagram
Blood Life
7/26/2013 8:53 PM
1.degreasing it and using light oil
2. degreasing and leaving dry
3. buy a hub that doesnt skip
oh and dont forget...all hubs skip from time to time
7/26/2013 9:00 PM
just take it apart and check everything....take it apart degrease everything and look at all the parts... if anything is even a tiny bit off replace it... i dont have much experience with a bunch of different hubs but i find it hard to believe it skips that much...
Deviant BMX store
7/26/2013 10:16 PM
it is true that all hubs skip eventually, but it should not happen often.. just take it apart.. apply a thin layer of grease all around it, then spray some chain lube on the pawls.. and spray it with chain lube every couple of months.. and while you have it apart, check to make sure the springs are working well and pawls are not sticking.. whatever you do, don't use wd-40 on it, and only apply a heavy grease to it moderately around the inner shell, but not to the pawls themselves or else they get really sticky.. use only chain lube if you want a louder hub.
-- Jean Rostand
7/26/2013 10:36 PM
I know! haha maybe redesigning the springs yourself and making them like a little stronger or something. I dont know haha. Do what imma do, im sure itll work. Imma buy the Cult Match asap and just get like 2 sets of springs and pawls and just replace them after a while. haha and of course messing around with the grease and whatnot. Or buy a coaster, set it to as little slack as possible, and those dont slip really. I mean coasters go out after a bit, but i have never had one skip or something.
7/26/2013 10:43 PM
Shitt, I have a wheel that is so fucked, I can pedal forward without the hub engaging, or moving.
Put in work.
Put in work.
Put in work.
Flacko put 'em in the dirt.
7/26/2013 10:59 PM
I tightened my wrap-around spring on my driver, degreased it, and used a tiny bit of light oil on all of the pawls and some on the ratchet. It's barely any oil but if I ever re-grease it, there's a chance it'll skip. I've had it skip twice throughout this whole year and it wasn't so bad. All my previous wheels skipped a couple more times but I used to run hubs fully greased throughout except the pawls and ratchet area so it was mad loud and everything.
7/27/2013 5:04 AM
Skipping doesn't always happen because the internals are dirty. Sometimes it happens because the panels haven't fully engaged the next notch before you start to pedal. Everyone wants positive engagement every time, and one way to get it is to increase spring pressure, but that will also cause the internals to wear prematurely.
7/27/2013 5:32 AM
rape the shit outta that hub...
Bruh
7/27/2013 8:36 AM
Edited Date/Time: 7/27/2013 8:38 AM
Haha I usually do
But I'm thinking if I just make the springs have more spring to them won't that lessin the chances of skipping
Reason I'm asking is because I want to sell my remix wheel but I want to fix it up so I don't feel like I'm ripping someone off
Honestly how much should these go for, I'm including the kenda tires and tunes 2 BSD guards for the front, primo dsg and S&m cymbal guards for the rear, I paid around $560.00 for the wheels and hub guards
:Photo
Small ding on the flange
Albes Is Rad!!!
YouTube
Instagram
Blood Life
7/27/2013 8:45 AM
Prolly 250 shipped for set. 140 rear and 110 front. Bike parts don't hold value for shit
7/27/2013 8:55 AM
Thanks, that sounds good to me hopefully I'll be able to sell them soon, trying to get a lighter wheel set for my girlfriends bike
Albes Is Rad!!!
YouTube
Instagram
Blood Life
7/27/2013 9:18 AM
Increasing spring pressure will absolutely result in a more positive engagement. That's just the way it works. However, if the ring has a groove in it, or the tips of the panels are worn, then increasing spring pressure won't help. Also, springs wear out. It doesn't hurt to give the springs a little tweak in the right direction from time to time, and it also doesn't hurt to have an extra set of springs around either.
7/27/2013 11:51 AM
Sounds good
Albes Is Rad!!!
YouTube
Instagram
Blood Life
7/27/2013 3:11 PM
Also, leaving the hub engaged when you set it down for the day helps a ton!! like not in between 2 clicks or something, that way the pawls arent pressed down for so long.
