well i wanted to know this cause im gettin a new sprocket
if the bore is 22mm does that mean it only works with 22mm spindles
my spindle is 19mm does that mean i have to get a sprocket with a
19mm bore???
19mm bore???
jeffgothro wrote:
Post edited by: jeffgothro, at: 6/4/2007 8:09 PM
unless you buy a tree sprocket that makes a 19mm bore then you wont need to worry about adapters for a 22mm bore sprocket
jeffgothro wrote:
Actually, Tree will make you any bore size you want...free of charge, they will even bore out another mfg's sprocket for you...however, there is a 10.00$ charge for that since they didnt make the sprocket, the free charge only applys to sprockets they make.
SBCdestroy
village idiot
You are full of good info!!
I am Mediocre!!
