Sprocket Concerns
5/24/2015 7:51 AM
Need new cranks bad
Running a 28t w/ 2 spacers, barely clears frame
Wanting Profile Columns or Thunderbolts
Want 30-33t tree lite sprocket
22mm tree spline drive only in 25 and 28t
Socket drive is limited on sprockets and diffferent sizes
Does tree make different inserts for the sprocket like profile does? or am I stuck with a 28t lite or a profile sprocket?
5/24/2015 11:14 AM
Tree makes a Tree Lite Spline Drive sprocket in 22mm, 30T, Black.
If you want a different colour, you could just get a bolt drive. The centre bore on a Tree Lite sprocket is 22mm and it comes with a 19mm adapter.
If you're getting Thunderbolts, the Tree Lite Socket Drive comes in 30 T black.
http://www.treebicycleco.com/parts/sprockets/lite-spline-drive/
Chris
www.bmxtransition.com
Canadian BMX Mailorder
Instagram: @transitionbmx
5/24/2015 4:36 PM
Planning on the Columns and they have to be spline drive. (boss less)
Profile makes the different inserts so that you can use one sprocket with multiple spindles/cranks.
I was wondering if tree made inserts, or if the profile inserts worked with the tree sprockets
5/24/2015 4:49 PM
Profile makes the different inserts so that you can use ...more
No, Tree does not, and the Profile ones would not work with a Tree Sprocket.
Also, I'm not even sure if a Tree 22mm spline drive sprocket would work with the Columns. I know that the United sprockets that I've tried will not work with them. Something about the way they do the American made splines vs. the ones made in Taiwan.
You may want to check out the Profile Galaxy sprocket if you're thinking about the Columns.
Chris
5/24/2015 6:01 PM
I got a 33t tree lite on my thunderbolts
5/24/2015 6:52 PM
Correct Transition Chris.
The profile isnt a proper 22, its a 22.2 or something to that matter, i cant remember off of the top of my head.
