Sprocket Size
3/5/2018 12:36 AM
I picked up a Subrosa Tiro with some aftermarket parts for $100 last night. When did the sprocket size get so small? Gearing is 25 and 9 in the rear. What gearing should i use for dirt jump and or flatlanding?
3/5/2018 12:43 AM
30 to 9
3/5/2018 12:45 AM
25 9 is pretty much the same gear inch as 44 16. But, if it feels too easy, get a 28t
Here's a gear inch chart for reference:
3/5/2018 4:55 AM
Get a 28 tooth #28GANG
Ride for yourself and have fun
3/5/2018 5:12 AM
For flatland most dudes run an easier ratio-like 22-10 etc.
For dirt, it depends on the trails you ride.
Quick acceleration = smaller up front, higher top speed = larger tooth count up front
It is about the same cost to change a driver on a cassette VS a sprocket (depending on the hub of course).
Just ride it for a while and see if you need it to pedal harder or easier or the same.
