Does it really matter which side of the sprocket you put the sprocket adapter on if you put a washer on the other side of the crank arm?
Dakota, will you be my sperm donor so that I can have babies that shred like you.- Ben C
Just try to have both crank arms the same distance away from your chainstays.
So would you suggest having a washer between sprocket and crank or one between sprocket and BB.
Put it between The Sprocket and the BB not the crank arm cos then it wont tighten properly
refs: Spikez5, cokacola, dacumup213 (x2), josh estey, Blake El Gingero, naters14, Harry95, pcoco, hattrckhcky, bstick, kevinl, Sunday.bmx21, dgisback, iridebmxeveryday, I RIDE
Sorry for the long response....
I have mine bb, adapter, spocket, and crank. Is there some special reson for you to need
a washer there? Otherwise you ok without it. Don't worry. Its actualy better if the sprocket bolt has more threads to to grip the crank arm tighter.
