6/19/2017 12:06 PM
Edited Date/Time: 6/19/2017 12:13 PM
Crank lenght doesn't affect pedaling much, with shorter you have less leverage which theoricaly makes pedaling harder but I didin't notice any difference about pedaling force when I switched from 175 to 170.
Gear ratio matters alot tho, I personnaly hate the 25x9 gearing, I ride a 28x9 for street and everywhere.
On trails theorically, the bigger the better but once you are launched you shouldn't pedal and just pump for speed, same for bowl riding, so just go for a gearing you like.
25/9 = 2,77
28/9 = 3,1
These numbers aren't just random number indication which would mean the higher the number the harder it is to pedal, it's true but the real meaning is for one full crank your wheel will do 3,1 turn on a 28 vs 2,7 on a 25, it don't seem like much but if you already tried both you know there's a big difference between these two.
