Sprocketos.
5/22/2011 8:25 PM
Edited Date/Time: 5/22/2011 8:26 PM
My sprockets made out of steel thats stronger than aluminum right? if so, sweet. it's a stock heathen sprocket i just started running since i got my profiles.i thought it'd be a bad thing but then i started thinkin about it. ha.
5/22/2011 8:32 PM
Chromo > aluminum
5/22/2011 8:32 PM
Edited Date/Time: 5/22/2011 8:32 PM
haha. aluminum can be made thicker but yet the same weight. i think aluminum is way better for sprockets.
A bike is not a bike if it doesn't have air in the tires.
BSD Front Street Hub Review
Primo Mix Review
Why You WEAR a mouthguard!
Refs.
\BMX-1995/
5/22/2011 8:57 PM
Kenealy wrote:
Chromo > aluminum
im aware. but im talking about steel.
5/22/2011 8:59 PM
chromoly is steel.
its regular steel mixed with chromium.
IN NOMINE SATANUS
5/22/2011 9:00 PM
ihatepurplebikes wrote:
chromoly is steel.
so, it's good to have a steel sprocket is what your saying?
5/22/2011 9:04 PM
i bet you its actually stamped aluminum.
Bike check?
5/22/2011 9:08 PM
Sprocket 25 tooth steel
unless vital's lying.
5/22/2011 9:17 PM
oh wow you are right,
also steel sprockets are more prone to bending while aluminum ones crack or shatter.
the aluminum one is usually better as a sprocket because it has a higher tolerance to crack than the sprocket's tolerance to bend.
Bike check?
5/22/2011 9:23 PM
ahhh, i get it. i'm not gonna replace because i SHOULD be getting a custom build in july. i already got it all picked out hahah.
5/22/2011 9:30 PM
Steel sprockets are easier to bend and aren't completely round so tight spots on chains are common
5/22/2011 9:54 PM
whatever he says, goes
refs: moyboy5, Gucci Mane La Flurr, jbeaton13, tinybikerider33, Lee_Rager,TCbmx, ultra blade, TerrorCrew, ~Stolen Boy~, bstick, ScramHype, AO8, Austin_Read
Albe's nigglets..
