Squeaking bmx cassette hub when i pedal help!
10/26/2013 5:35 AM
Its 100% the hub not the chain or bb or cranks
10/26/2013 5:50 AM
Grease everything.
It might be the spokes too. Check if they're loose
I'm gonna need bigger bars
10/26/2013 3:48 PM
Edited Date/Time: 10/26/2013 3:50 PM
Do you run your chain really tight? What hub?
10/26/2013 4:15 PM
are you POSITIVE it's not the cranks? a lot of times, splined cranks will develop a wobble, especially 8 spline cranks, and when you pedal, they'll squeak. try taking the arms off and greasing the splines, put them back on, then see if the problem persists. If not, we'll move onto your hub
10/28/2013 7:36 AM
Lube your driver, your chain, your cranks, your pedals and ALL bearings.
If it still persists, it is not your drivetrain.
