Skylight wrote:
This has probably been touched upon up there, but I'm throwing my 2cents into the equation.
Sanding will help. It wont reduce ...more
Sanding will help. It wont reduce contact area of whatever-it will increase the friction coefficient by giving a rougher surface to mate onto.
I had problems too, altho my bars and stem where knurled. Here's what you could do:
-Start by sanding as you propose, perpendicular to the bike.
-Loosen a few grains of sand, then tighten your bars into your stem. Use a rubber-coated hammer and knock the bars from side to side (side to side as in perpendicular to the bike).
-Scratch in a few X/diagonal lines with a scalpel/knife. Being aluminium, it should be easy.
-Clean the interface area REALLY well. Use soap. But get it clean as hell.
-That should do. If not, you can always put in some loctite in there to get things nicely stuck.
am glad you threw your change in, thank you
So your stem was knurled- what stem is it?
The grains-of-sand thing, is that your idea or did you learn it? I find it intriguing but I'm afraid it could work against the purpose here, if for no reason other than the fact that you'd need homogeneously-sized grit to do it properly (otherwise the strongest groove would prevail right? Or does it not matter, because it's not the recesses, but the metal that was pushed out during their carving, that does the biting?)
Scratching lines- why diagonal? I would have thought perpendicular..
Cleaning- oh yeah, I'm a nut when it comes to metal-on-metal lol,anytime I do anything on my bike, better believe the threads&surfaces are all cleaned and re-lubed or, in the case of clamping, are cleaned with isopropyl alcohol!!
Loctite- lol I couldn't even imagine! It's not a bad idea really, sounds like it'd help - have you heard of "Carbon assembly gel"? It seems to be a carbon grit (suspended in some kind of evaporating solution maybe alcohol) that's used by car mechanics for metal-on-metal 'bite', have been wanting to go find it for a while I think it'd find perfect application here, seat-posts, etc any spot where it's metal clamping on metal instead of bolting-into it.
