http://www.chainreactioncycles.com/es/es/bicicleta-de-bmx-stereo-bikes-5-aniversario-ltd-edition-2014/rp-prod106682
What u think about this bike? It's worth the 650 Euro?
It looks like a pretty good bike, but there are better bikes for the prize.
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
The top review is the best. Rasta is played. Get what you like. There are better bikes, and ones that actually have aftermarket parts on them for that price.
And, what do you think about the WTP Envy? I think it's too expensive for the quality... What do you think?
Its amazing. Has aftermarket parts. The fit WIFI is awesome aswell.
RIDE OR DIE
THE ROUTER
That might be a little too big. If you run them with front load stem you will be fine.
RIDE OR DIE
THE ROUTER
Nop, go for another bike, bikes that are 650€ usually have some aftermarket parts.
RIDE OR DIE
THE ROUTER
Not stock one, for example my fit WIFI frame, my shadow noctis cranks, my rims, my fly ruben pedals, or whatever stuff that is sold separately
RIDE OR DIE
THE ROUTER
Yeah it is. But if you keep bmxing you will most likely end up with a full custom bike.
By the way, the shadow novus is 700 in chainreaction cycles and is pretty good. Obly those cranks are 160€.
RIDE OR DIE
THE ROUTER
Subrosa Novus* Yeah, but, i dont like the colors and... they are same materials almost...
if something is chromoly.. it'll last ...
Is full cromo and all the shit, and you shouldnt care about the colors, by the way whats your budget?
RIDE OR DIE
THE ROUTER
700eurs not more...
I look for weight, 21'' or 20.8'' frame, full chromo..
and if the colors are good then yeah.. sweeeegg increaseed!
Thats a pretty good budget, i will check some websites. The weight is not a problem, all good completes are light, coming from a decathlon every bike will be light
RIDE OR DIE
THE ROUTER
For the momento your best bet is the shadow novus. You can also go with a worse bike and save cash to upgrade it progresivelly
RIDE OR DIE
THE ROUTER
well, thanks guys...
I'll see what im gonna do...
Cuz tomorrow im gonna order one.. i think the stereo.. but idk
for that price, get a build kit and pick out a frame you like to go with it
kokyandrei wrote:well, thanks guys...
Olease dont. You can get am aftermarket frame and a build kit with that budget.
RIDE OR DIE
THE ROUTER
kokyandrei wrote:But what's the difference?
Si las piezas estan hechas igual...
Te lo voy a explicar en español para que lo entiendas bien:
Las piezas no están hechas de la misma manera, unas usan procesos de calor para que sean mas resistentes, la diferencia estre piezas que vienen con una bici completa y las piezas que compras aparte es abismal. La calidad de los ejes, si son macho o hembra, si es 2xbutted o el numero que sea, la geometría, longitudes, altura de manillar, numero de estrías de bielas.
Me parece bien que te quieras pillar la eñstéreo por el color rasta, pero yo no lo haría ni de coña, hay.mejores cosas por menos y hay mucho mejores por algo más.
RIDE OR DIE
THE ROUTER
Ya pero, no se, yo estoy acostumbrado a mi bici, que no se si tiene 19 o 20 el frame...
con un manillar de 6 o 6.5, la unica diferencia que tendria seria lo que has dicho de la preparacion y endurecimiento de los materiales... pero no soy un rider muy agresivo... hago los trucos que hago y intento algunos, y creo que esa bici me podria durar hasta que vuele o mas...
conozco a amigos que tienen HT DT de chromoly y el resto de Hi-TT, y le dan unas hostias... pobres bicis, y no se rompen...
y elegir las piezas, ver si cuadran, las medidas, (no tengo ni puta idea de que medidas me valdrian, cual me sentiria comodo), y pff es un rollo
