Stock fit Mac or sunday 2013 soundwave
11/3/2015 6:20 AM
I've heard good and bad things about sunday and I wanted to compare the frame I have (2014 fit Mac stock) to a barely used Sunday frame a guy I know has. All help appreciated!
11/3/2015 6:56 AM
Soundwave (I assumed the complete bike frame) Sunday Soundwave, 41-Thermal, full chromoly, aftermarket w/ Wave TT & DT, hollow dropouts, integrated chain tensioners and removable brake hardware.
Fit Mac:
Mac 1: CrMo Front Triangle
Mac 2: CrMo Front Triangle and Chainstays
Mac 3: Full CrMo Frame
If you have the Mac 3, they will be similar to an extent. If you have a Mac 1 or 2, it will be a very solid upgrade assuming no cracks or bends or dents.
11/3/2015 10:51 AM
sunday
11/3/2015 3:45 PM
Fit Mac support shitty
11/3/2015 4:29 PM
The soundwave will be better than any stock Fit frame. Get the soundwave
11/3/2015 6:41 PM
This! It is also probably better than any after market fit frames.
IG
@curtis_cantbmxwell
11/3/2015 6:49 PM
So we got a Stock Fit Mac frame vs arguably one of (if not) the strongest frames made backed by a much better warranty?
No contest, even though I'm not sure which level Mac you have, the Sunday dwarfs them. It'd be a lot closer if it were the aftermarket one but even then I'd say the Sunday hands down and that's not even a biased opinion either.
Assuming the Fit frame you have is a higher end one like the Mac 3, it still pales in comparison to the Soundwave because generally even if it's a full chromoly stock Fit frame, it's likely not heat treated at all whereas the Sunday is fully heat treated. Also the weld quality and such is usually lower on stock frames, and they typically don't carry much of a warranty if at all, which isn't saying much cause Fit doesn't offer lifetime warranty whereas Sunday does.
