Stuck mid bb
10/23/2013 3:00 PM
I want to take my 19mm mid bb out so i can switch to my powerbites. I already tried tapping them out with a socket extension. I got to the point of wailing on it with a hammer, but they didn't move at all! This is the only way i could find to get them out and it didn't work. What can i do to get the bb out?
IG
@curtis_cantbmxwell
10/23/2013 3:03 PM
Put it on something level like a table, angle it right, socket extension, and hammer them out. If theyre really stuck its gonna take a while hit equally around the bearing.
10/23/2013 3:03 PM
try greasing the edge some could slide in and also try using a wrench to hold the socket in place so you can hit it harder
10/23/2013 3:08 PM
Edited Date/Time: 10/23/2013 3:09 PM
I always use an old axle and a lump hammer, you can use anything with a large surface area really, just don't use a screwdriver.
The socket extension should be fine, just make sure to hit it evenly at the top, bottom, left & right sides.
Seriously hit it harder tho & it'll come out.
dangerous thing.
to do a dull thing with style
without it.
Os 94
Ms 01
Ns 12
10/23/2013 6:49 PM
I was hitting as hard as i could...
IG
@curtis_cantbmxwell
10/23/2013 7:16 PM
Spray some wd-40 in there and wait over night they should pop out tomorrow.
Put some grease in there when you install the new ones man.
