Switching to LHD?
2/17/2017 12:49 PM
So recently I have been doing alot of dirt jumping and trails, but I want to do grinding with pegs and stuff but I have RHD and I am right foot forward.
I know that some rear hubs are changeable but I want to know if you can switch the cranks over as im not to bothered about spending some money on a new wheel.
My cranks only have a sprocket bolt on the right crank so I would have to switch the cranks over with the sprocket. However this apparently makes the pedals loose from the way the turn so I was wanting to know if there is anything that can be done to go around this?
Would either switching the pedals aswell or not switching them make the pedals tighten?
thanks anyways.
YouTube:
https://www.youtube.com/channel/UCMarY8ceoNhZjkyWXT2jcHA
Trails not Rails
Trails YT Channel
2/17/2017 1:31 PM
switch the spindles in the pedals and all will be fine.
REFS-
2/17/2017 2:15 PM
do u have 48 spline cranks?
cause if you do, just get the spline drive sprocket
2/17/2017 2:39 PM
You can also grind without any issues on your setup now. I run 4 pegs, lsd, left foot forward and Ive never had a problem with my sprocket side My switch and regular are equal
REFS-
2/17/2017 11:31 PM
you could do the cheapo way and buy a sprocket guard and a drive side hub guard. it worked for my friend who didnt have an lhd wheel for a long time so he kept it rhd
2/18/2017 3:41 AM
No, 8 spline cranks
Trails not Rails
Trails YT Channel
2/18/2017 3:48 AM
I think you should just switch the pedal spindles around.
Wake up, ride, have fun, repeat.
2/18/2017 3:50 AM
Coopers25 wrote:
you could do the cheapo way and buy a sprocket guard and a drive side hub guard. it worked for my friend who didnt have an lhd ...more
isn't it possible to change some hubs to LHD by switching the springs over
Trails not Rails
Trails YT Channel
2/18/2017 3:51 AM
Depends on the hub.
Getting a guarded sprocket and drive side hub guard is the cheapest option. You could get them for less than the price of a wheel
