The plan
11/21/2017 4:50 PM
OK so I plan on changing a few things on my bike.
I am changing frames this Christmas and then buying a back wheel shortly after.
The questions I have are:
When I replace my tires should I use a fly ruben up front and an S&M mainline in the rear or ruben front and rear?
And what are some good 160-165mm cranks in a 19 or 22mm spindle?
Hmmm
11/21/2017 5:06 PM
If you're looking for 22mm cranks I have the Shadow Conspiracy Killer Cranks and I love them! I think they come in 160mm-165mm....
11/21/2017 5:47 PM
Profile cranks go all the way down to something crazy like 145, if I remember correctly.
11/21/2017 8:26 PM
Thunderbolts!
11/21/2017 8:36 PM
Edited Date/Time: 11/21/2017 8:36 PM
Bulletpup wrote:
Thunderbolts!
Yes or these, Thunderbolts are also good...
11/21/2017 8:52 PM
I have Ruben's front and back and they're great all around tires. Have profile 165mm race cranks and I also recommend (lifetime warranty) them. Mainline is one of my favorite tires as well but only up front
@coupd_tat
11/21/2017 11:10 PM
The mainline has a pretty aggressive tread, I'd say it's a front only tyre, even if all you ride is trails.
Why do you want such short cranks? Are you 4' tall?
11/22/2017 12:12 AM
Why do you want ...more
Isn't that what everyone is riding right now?
11/22/2017 12:35 AM
The 2.1 mainline and the 2.4 mainline have a different tread design for front and rear, is the 2.1 still a very aggressive tread?
And Im 6' tall but guess I just want to have trendy short cranks haha. I have rode a set of pride street cranks in 165 and they felt good though so fitting them won't be an issue.
Hmmm
11/22/2017 5:16 AM
I think I'm going to go for odyssey cranks. Is there really much difference between the calibur and the thunderbolts except for the wedge? Because I like the look of the caliburs more but obviously if there is a good reason to get the thunderbolts instead then I will.
Hmmm
11/22/2017 6:05 AM
Edited Date/Time: 11/22/2017 6:07 AM
Thuderbolts are easier to deal with, you dont have to line anything up. Crank wobble will never develop because of the design. They are 2 peice, one side is welded on so you never have to worry about that loosening. 1 bolt to tighten. Super hollow axle, lightweight. The arms have a nice taper to save weight and rounded off edges in case you hit your ankles on them.
11/22/2017 2:20 PM
Bulletpup wrote:
Thuderbolts are easier to deal with, you dont have to line anything up. Crank wobble will never develop because of the design. ...more
The thunderbolts It probably is then!
Hmmm
11/22/2017 2:36 PM
Edman123 wrote:
The 2.1 mainline and the 2.4 mainline have a different tread design for front and rear, is the 2.1 still a very aggressive ...more
Yeah, I used to have a 2.10 up front, it's definitely a dirt tyre. Have a look at fit faf's if you can find em. The 2.25 have a slightly more aggressive tread than the other sizes, but that's what I use front and back.
I really can't imagine short cranks feeling good, if anything I'd rather get longer cranks myself
11/22/2017 3:04 PM
Yeah, I used to have a 2.10 up front, it's definitely a dirt tyre. Have a look at fit faf's if you can find em. The 2.25 have ...more
I'll have a look at fafs I've heard they're quite good. But if I can't find any I'll probably use rubens for both if it fits in my frame.
And I think that things like geometry and cranks is just what you're used to. I don't notice tiny things like one half link of chain like you have mentioned in other threads so I don't see any problem adapting to shorter.
Hmmm
