Tire Pressure Q?
12/31/2011 8:24 PM
How much should your weight effect your tire pressure? I weight 190 and i'm running 60 in the front 90 in the back. Any advice or tips?
12/31/2011 8:27 PM
you should run what it says on your sidewalls
12/31/2011 8:29 PM
160lbs, 55 in front and 65 in back
2Hi throwaway
Anti-street?
NEWER VIDEO
TRV-950 Footy
12/31/2011 8:32 PM
i weigh about 140lbs. i hav 50-60 in each tire...
12/31/2011 8:37 PM
150lbs 80psi in both atleast
12/31/2011 8:43 PM
110lbs 110psi in both tires.. i go so fast and its 100x easier to air out
1/1/2012 6:56 AM
i was wondering about high pressure in a 2.35 tire. If i use a reg tube isnt running 110 psi kinda stretching it?
1/1/2012 10:25 AM
I weigh 140ish i run 100 psi in both tires i recommend this because i get a hell of alot less flats with 100's hope this helps
Just remember mainstream is expensive. Your paying for the name, not the quality
PSN: FrozenInferno166
1/1/2012 11:02 AM
this
1/1/2012 1:27 PM
I'm 165 and run about 80 in both of my tires. I would probably say it has a lot to do with preference and feel, and what the tire is rated for on the sidewall.
Washed Up
Refs- bmxryder2001, NikeOGD, Nike_iD, \BMX-1995/, Daniel 21
1/1/2012 3:03 PM
i run 60 in both so theyre not too hard and you wont hurt your wrist when you land flat
...The ONLY thing skateboards are good for, is filming BMX edits...
1/2/2012 11:14 AM
My tires say the min pressure I can run is 85psi and max is 110psi.
I got them just under 100 each.
Does it matter if I run them under the min psi?
1/2/2012 11:15 AM
it's personal preference, in my opinion.
apparently lower psi wears tires faster, but i haven't seen a huge difference. i like my tires right around 65psi, front and back.
1/2/2012 11:28 AM
well not until recently i started using a higher tyre pressure, you go alot faster, higher and take off better to spin faster. i was trying 540 airs, i was only getting to 450. pumped my tyres up because my friend told me to. and i landed it first pop.0
1/2/2012 12:03 PM
145 and 110 psi in both
Just ride and stop being a DICK to the new kids
