Tire psi?
7/14/2018 3:17 PM
I got a fit hango and the tires only go up to 60 psi. Just gonna be riding street right now and until I get money for new ones could i run 50 - 55 or would there be a good chance of popping it. I just dont want a pinch flat and the tires feel squishy at the moment (running around 40 right now)
7/14/2018 3:25 PM
You seem to have answered your own question in the very first sentence of your post..
7/14/2018 6:26 PM
Tyres never have their failure pressures on them. The failure pressure is usually about twice the rating on the tyre to account for bad/heavy landings.
7/14/2018 8:33 PM
I like to run 60 for street (maybe 65 in back) and 85-95 for park. Dirt, I play it by ear. As long as the bead is seating good you are fine with 50-55 but with 50, keep an eye on the bead. The tire can burp off at times at certain angles. Like a goof on a 180 and you land kinda sideways.
7/14/2018 9:32 PM
Gack2000 wrote:
I like to run 60 for street (maybe 65 in back) and 85-95 for park. Dirt, I play it by ear. As long as the bead is seating good ...more
How havent I got a flat then lol? Ive been landing sideways trying to learn 180s lol, i guess its time to pump them up a little bit
7/15/2018 12:17 AM
Go with at least 60 if you are riding street. You will notice tricks become easier cause your tire isnt rolling over the side of the rim as much. More predictable. I have run 60psi rated tires to 80psi with no problems. I cant say you will have the same experience I have had but take it for what its worth.
I do still run anywhere from 40-60 psi roughly for dirt and it seems to help get a bit of extra traction. Could be just a perceived thing and not reality. Lol
7/15/2018 5:35 AM
Pumped my tyres up today, they were a bit soft. Turns out they were only at 30psi! I usually pump mine up to 60 and sometimes feel like I have to let a bit out. 50 is what I really like but it feels a bit too soft if I'm doing something big or a fairly fast spin. At 50ish I've never got a puncture from pinching or debris, and I've never had my tyre roll off my rim.
The only reason I checked and pumped them up today was because I could feel it roll a bit trying a line. I reckon I'll get the line next time I try now (it's too hot and busy to try again now).
My riding involves a lot of 180's and bump jumps, so......
7/15/2018 9:10 AM
Pumped my tyres up today, they were a bit soft. Turns out they were only at 30psi! I usually pump mine up to 60 and sometimes ...more
Wait Is my psi why i keep landing lopsided when i try to spin? or could it be one of the reasons?
7/15/2018 9:23 AM
That's highly unlikely(although not impossible); that's usually just a problem with your technique.
7/15/2018 9:53 AM
Landing lopsided usually means you're carving too much. But if your tyres are too soft they'll absorb loads of your effort. I was doing 180's no problem with 30 psi. But I've been doing 180's for a long time
7/15/2018 10:10 AM
Edited Date/Time: 7/15/2018 10:10 AM
I like these bsd donnastreets I have now at about 40
Hmmm
7/16/2018 3:11 AM
don't give a shit about what the mark on the tire says.
back then, we ran way more psi than marked and now i run stupid low pressure.
never had issues with flats.
IG: @_almost_crook
7/16/2018 10:45 AM
Edited Date/Time: 7/16/2018 10:46 AM
>When you land a sketchy 180 and feel your tires compress and bounce unsure unsure
7/21/2018 7:59 AM
I run 75psi. Seems to be the best compromise as I ride street and park usually in the same day. Any less and I feel my tyres rolling while carving which is horrible, any more and hard landings are painful.
