Tires skinnier than advertised?
4/4/2018 11:02 AM
I recently bought a Cult Dehart tire. It looked skinny when I mounted it, so I measured it to be 2.28" instead of the advertised 2.4". Does anyone know why this is?
4/4/2018 11:03 AM
VenomousDancer1234 wrote:
I recently bought a Cult Dehart tire. It looked skinny when I mounted it, so I measured it to be 2.28" instead of the ...more
Did you inflate it to the maximum psi?
If you did, you likely bought a tire in 2.25 size by accident, or they shipped you the wrong size.
-Sheldon on Adam22
"The only future for BMX"
-jbales on mafiaBIKES
-adamnmexican
4/4/2018 11:06 AM
Edited Date/Time: 4/4/2018 11:07 AM
What pressure are you running and what is the inner width of your rims? Low pressure will mean your tyres don't inflate to full size and the same for skinnier rims. Also, most tyres I've had have had a "stretching" period, after which the tyres should have reached full size(usually larger than advertised).
4/4/2018 11:07 AM
No. The package said 2.4" and they don't offer the slick in a 2.25. When I purchased the 2.4" the 2.3" was unavailable.
4/4/2018 11:08 AM
What does it say on the tyre though?
4/4/2018 11:12 AM
Edited Date/Time: 4/4/2018 11:15 AM
I run them at about 100-110psi so there's no reason why the tire is under the advertised width of 2.4". Also, I've been riding on that tire for a few months now. The rims may be the issue, since the max width is 2.4". The tire says 2.4"
4/4/2018 11:17 AM
Inflated Size and Advertised Size are two totally different things.
Its pretty stupid, but you have to look at the Inflated Size when shopping for tires. The advertised size means pretty much nothing.
There's 2.25 tires that inflate to 2.4, & 2.4 tires that inflate to 2.25.
Dan's Comp is the best place to check for Inflated Sizes, they're one of few places that actually list it in the specs.
Also keep in mind, as you ride the tire and wear the rubber in, it will kind of loosen up & stretch a bit, making it a bit wider.
4/4/2018 11:19 AM
I run them at about 100-110psi so there's no reason why the tire is under the advertised width of 2.4". Also, I've been riding ...more
What rims are you running them on? Also, what size does it say on the side of the tyre?
Tyre sizing isn't an exact science at the manufacturing stage; very slight changes in how something is done can result in massive variations in size between each tyre/batch, especially with lightweight tyres like BMX tyres.
Also, why does it matter so much? If they grip well and you're not having any actual problems, why worry about it?
4/4/2018 11:22 AM
Its pretty stupid, but you have to look at the Inflated ...more
Thanks. Lesson learned
4/4/2018 12:01 PM
Tyre sizing isn't an exact science at ...more
its all about the looks bro
4/4/2018 12:52 PM
Surely that's a good thing? Who wants tyres that wide anyway?
4/4/2018 12:57 PM
because you touch yourself
4/4/2018 12:58 PM
are your calipers iso 9000 certified? can you provide calibration records for said calipers?
4/4/2018 3:39 PM
Tires are kind of a hit or miss , some 2.25 tires are almost 2.4 , and some 2.3 tires are more like 2.2 .
4/4/2018 3:52 PM
Why do you want your bike to be a floatation device ?
4/4/2018 7:14 PM
Alright man so the 2 inch platform is kind of bunk. What you look for is inflated diameter or something. Should be anywhere from 54MM-64MM
4/4/2018 9:16 PM
All of these carefully—and appropriately—crafted paragraphs.
4/4/2018 9:17 PM
And then this one, too.
4/5/2018 12:34 AM
You're welcome smile
