Top & bottom tube sizes?
1/29/2016 7:33 PM
When i get my tax return back im ordering a custom frame. I know all the geo i want i just don't know the top and bottom tube diameters i want. Whats better 1.25" or 1.38"???
1/29/2016 7:55 PM
One is bigger than the other.
1/30/2016 10:43 AM
Yes i know. I'm just wondering if theres any advantage to having bigger tubes
1/30/2016 10:54 AM
Bigger tubes more surface area to bash off of things
1/30/2016 10:56 AM
A wider tube will be more resistant, against denting especially.
The theory is : the wider the tube, the less material thickness you need to get the same strenght.
So If the thickness is the same, the wider tube will be stronger.
1/30/2016 11:44 AM
Larger diameter gives more area to weld. Usually the downtube would have a larger diameter as the weld between it and the headtube will take more abuse. A larger diameter of the same gauge is easier to dent. Which is why straight gauge is often used on the downtube for street frames.
1/30/2016 2:32 PM
Thanks for all the comments guys.
