Trail Gearing?
11/25/2011 9:00 AM
What gearing should i ride for trails? im thinking about going 28-9. i have 170mm cranks now . but i plan on getting some odyssey thunderbolts or kink pillars in 175 soon
11/25/2011 9:26 AM
run 32 9
11/25/2011 9:26 AM
Don't know much about trails, but if you're gearing up.. getting longer cranks is a great idea.. I'd go with 177 or 180mm (depending on your height).. the wider footing should give you a better base and more stability.. and from what I've heard, higher gearing helps for pumping through trails..
-- Jean Rostand
11/25/2011 9:36 AM
28-9 or 30-9. i run 28-9 and i love it
11/25/2011 10:13 AM
i run 25-9
honestly i don't see the need for harder gearing unless you have to pedal mid run, otherwise its kind of pointless.
Bike check?
11/25/2011 10:58 AM
cupovjoe wrote:
i run 25-9
yea i see what your saying but some times on my bike it seems way to easy to pedal
11/25/2011 11:09 AM
i run 28-9 and its perfect imo...when i ride a 25-9 now it feels like i dont go anywhere when i pedal
Save a Tree, Ride a bike!
11/25/2011 12:05 PM
NIce trails usually don't require pedaling hardly at all to be honest. You just use rollers berms and jumps to gain speed. Some trails start off with little 5 foot gaps and end in 35-40 footers, they truly are a work of art. smile
Swoop it motherfuckas
11/25/2011 2:14 PM
1234, if your trails go down hill then whatever you are running will work just fine. However, if your trails require you to pedal a lot like mine than step the gear up, I run 27-9 on trails that are completely flat and require you to pedal inbetween sets.
Refs: ScramHype, Wade, jwnolte, beastassdick, ///digitalme, iridebmx2122
11/25/2011 4:30 PM
i ride alot of different trail though. like i ride some near my house that are down hill and you dont need to pedal but i also ride some that i need to pedal every so often
