Tree hubs
1/9/2015 4:29 PM
Looking to buy a rear Tree hub and ribcage, but am in a predicament
The frame I have now has a 14 mm axle, but in the future, i'm looking to buy a frame with a 3/8 size axle. Is running a 3/8 axle with 14 mm adapters a sense-able option?
36h
RHD or LHD (black or silver only)
requires straight pull spokes (sold separately)
17mm female heat-treated steel axle with 3/8" square head bolts
unique bearing system eliminates loose/tight bearing illness
ceramic driver bearing
hubguard included
On Empire, it lists that it has a 17mm axle with 3/8 bolt heads. So i'm guessing it goes on a 3/8 axle?
Finally, I want it in silver, but i'm not sure if silver means raw, silver paint or if it's polished
1/9/2015 4:35 PM
That one would be 14mm. The 3/8" refers to the size of the ratchet used on the bolts. The silver is a polished raw. Not super high polish, but enough to shine.
1/9/2015 4:41 PM
Xxohioanxx wrote:
That one would be 14mm. The 3/8" refers to the size of the ratchet used on the bolts. The silver is a polished raw. Not super ...more
Well that's not as clear as it could be... Guess i'll have to shimmy over to Dans
You think running a 3/8 female rear hub on a 14mm axle w/ adapters is sustainable for a few months?
1/9/2015 4:46 PM
You think running a 3/8 female rear hub on a ...more
You should be fine if you just ride trails/flowy park.
IG
@curtis_cantbmxwell
1/9/2015 4:50 PM
I dunno man, you get a guy racking a set of doubles and ya never know
1/9/2015 4:55 PM
Its a true 14mm female thing. Not a 3/8s axle. although they do make those, this hub is not that.
1/9/2015 5:48 PM
Why do you want 3/8"? When it comes to the tree hubs, the 3/8" and 14mm versions aren't noticeably different in weight. In fact i.think the 3/8" is heavier because it uses chromoly bolts and.the 14mm uses aluminum.
1/9/2015 5:54 PM
HardBMX_Tim wrote:
Why do you want 3/8"? When it comes to the tree hubs, the 3/8" and 14mm versions aren't noticeably different in weight. In ...more
My back wheel isn't doing too hot, if I get a new one I would need a 14mm axle
I'm going to buy a frame that has a 3/8 axle hopefully sometime in the near future, so I don't want to buy a hub with a 14mm, then buy a whole new one 4 months later. I also don't have money to buy a $370 frame and a $300 wheel at the same time.
>not a weight whore
1/9/2015 6:00 PM
I'm going to buy a frame that has a 3/8 axle ...more
Ah Alright. Well, 3/8" with adapters is just as strong as 3/8" in a 3/8" dropout. So you shouldnt have any problem until you get your new frame.
1/9/2015 6:02 PM
The 14mm bolts are chromoly but you can buy the aluminum ones . The 14mm aluminum are well strong enough for heavy peg use, Ive run them for a few years now with no problems.
Yes, 3/8 bolts with adapters will be fine? I run profile 3/8 in back with pegs and have never had a problem so asking if the Tree hubs will be fine, ABSOLUTELY!
REFS-
1/9/2015 6:04 PM
The Horror Contact wrote:
The 14mm bolts are chromoly but you can buy the aluminum ones . The 14mm aluminum are well strong enough for heavy peg use, ...more
This. The 14mm bolts are chromoly, not aluminum. And 3/8" will be fine in the rear, especially if you don't run pegs.
1/9/2015 6:04 PM
Why are you buying a 3/8th frame?
IG
@curtis_cantbmxwell
1/9/2015 6:06 PM
I'm not buying it because it has a 3/8 dropout, it's just a trail frame that happens to have a 3/8 dropout
lol
1/9/2015 6:11 PM
My.friends V3 came with aluminum bolts. Weird.
1/9/2015 6:15 PM
Where was it purchased from? Mine was definitely chromo and I switched it out. I even talked with Sam before so and he told me there were no problems with anyone on the team running them with pegs also.
REFS-
1/9/2015 6:18 PM
Where was it purchased from? Mine was definitely chromo and I switched it out. I even talked with Sam before so and he told me ...more
From Tree/Plannine.
1/9/2015 6:22 PM
Clueless, darn good hub though...My wheels are still tight and true throughout the years and I have yet to everv adjust them?
REFS-
1/9/2015 6:40 PM
Edited Date/Time: 1/9/2015 6:43 PM
You'll be fine especially being pegless. I run pegs with adapters on my 3/8" bolt G-sport ratchet hub on a frame with 14mm slots.
1/9/2015 7:09 PM
Clueless, darn good hub though...My wheels are still tight and true throughout the years and I have yet to everv adjust them? ...more
What rim do you run and who laced it?
1/9/2015 7:12 PM
Gsport Birdcage rims,Albe's did mine.
REFS-
1/9/2015 7:15 PM
I see most people run birdcage rims, I would think everyone would be riding ribcage
is it the looks, the weight, maybe i'm missing something
1/9/2015 7:20 PM
I was into them when first coming out due to the rotational weight savings , they are good rims, I've never had a problem. .I also ride ribcages as well
REFS-
1/9/2015 7:39 PM
is it the looks, the weight, maybe i'm ...more
Birdcages are strong enough for 97% of people, and they're light which feels awesome, plus they're a bit cheaper than Ribcages.
1/9/2015 8:09 PM
I weigh 220 lbs, have a ratchet to birdcage with the 3/8 kit in it. I occasionally run pegs and have never had an issue. I have a custom frame with 3/8 dropouts and my current frame with 14mm dropouts, which I use adapters with obviously. also never had issues as far as my dropouts go. my only issue with my rear wheel is that I wish I had gotten a rollcage or ribcage. my birdcage comes untrue pretty often but that's mostly due to my weight and riding style. a lighter and more smooth rider would probably be fine with a birdcage.
selling refs: see profile
Instagram
1/10/2015 11:20 PM
Ryno lite xl rims are better
Testimony and apologies
instagram
old edit
1/11/2015 12:07 AM
I'd say if you're a lightweight guy who isn't sloppy birdcages will last. Rollcages are bombproof , you can get away with Birdcages
