I have 2.25 tires and don't know what tubes to get as I can only find ones for 2.125 and I don't wanna buy $10 tubes I just want cheap shit
Anywhere from 1.75 - 2.3 tubes will fit any BMX tire . I've seen those fuckers get fat as fuck at my local shop !
All tubes will fit, regardless of their size (by size I mean width). Of course, you cannot put a 26 inch tire in a 20 inch wheel...
The problem with skinnier tubes is that they are going to leak and are more prone to pinch flats if you are a diehard low-pressure dude. Like me.
I hate heavy tires, and I love low pressures. After having so many pinch flats and becoming an ace at installing and removing a tire, I went for an Innova tube: it had a thickened crown...
I just broke my second one-it cracked around the valve head. Sucks-I don't know what's going on, I install the tube correctly. No user error, at all. The tube is thick as fu*k and weighs nearly as much as a tire, but it's weakness is around the valve head... Then I discovered some rubber balls in my tire-and I pretty much guessed what was going wrong.
As the tube is thick, it does take quite a bit of pressure for it to expand. I was running it right on the red line-that is, the inferior red line. There was a sort of micro-void between my tire and tube, nothing which baby powder could have helped (maybe made it worst), which allowed for separate movement of both elements-hence creating those rubber balls and rubber deposit. It sucks as it happened on my kink lyras (on the rear) and I love that tire... Still, it is going good, and I need to find a cheap tube alternative. I am considering moving on to a tubeless setup, as I don't really ride that aggressively and my tire is hard to bead (an unbead) as hell-it should take care of any side loads...
Thing is-do I do this after my summer france trip or before? its going to be damn impossible to repump my tubeless setup without a compressor with air at an instant 120 psi...
Good tubes, anyone?
Giant (mtb brand) heavy duty tubes and danscomp tire liners are bomb proof it would cost about $25 but you won't need to spend money on tubes for a long time. Think of the money saved over time because you spent 25 on a good tube set up once
80 PSI and then I run it for like 2 months, then back to 80 PSI.
michael.eckhart wrote:I just get the 20" BELL tubes from Walmart, they work just fine.
THIS
| (• ◡•)| (❍ᴥ❍ʋ)
