tomdon wrote:
lets make this happen. bracket style. games of 1v1, winner moves on. put it in the photo/video section since that doesnt seem ...more
tomdon wrote:
lets make this happen. bracket style. games of 1v1, winner moves on. put it in the photo/video section since that doesnt seem to get as much use as anywhere else.
I'd be into that.
something like that.
I'd be down to play, let's mod the rules a bit.
-must set next trick or upload vid of completing trick in 1 day of trick being set (will make exceptions to weather)
-sketchyness should count. it's a game of bike, not Dew Tour. same with indian gives, as ugly as stuff like that is.. it still counts. unless of course say someone does a 180, his opponent cannot 180 and does like a 120, to pullout the other way. that would not count obviously.
-peg tricks can count, but not if your opponent doesn't have pegs. same goes with switch pegs, if your opponent does not have them.. no switch grinds. also applies to brake tricks. you must clarify how high the ledge must be, for instance someone would set "feeble grind to 180 on fork height ledge/under stem ledge" or something.
-no ramp or fly out tricks unless both have ramps accessible, but a bank will suffice.
-must show that it is you doing the trick not a friend on your bike.
How will the turns/letters go? I know people play differently. The way I'm used to is if A, B & C play bike and A sets the trick, B & C both have to do the tricks & whoever messes up, gets a letter. The trick then goes to B, who does the same thing and A & C then have to do the trick.
But I know some people play it as A sets the trick, then B does it and if B lands it, then C has to do the trick. But if B doesn't land it, B gets a letter & C doesn't have to do the trick, then A begins setting the trick again
