WTP LOFI
2/11/2010 2:47 PM
does anybody know the geo on the WTP lofi frame?...i just came into posession of one.. and i cant find the geo anywhere.. im pretty sure the backend is 13.25 slammed..and the BB is 11.5?..idk someone help a brotha out!
team fatcats fer life.
2/11/2010 2:56 PM
Edited Date/Time: 4/15/2016 12:55 AM
BB: Height: 11.75”, new shape Mid size BB - Headtube: Int. Headset, included gyro tabs - Toptube: 20”, 20.75” and 21.25” Dropouts: Lasercut, 5mm,CrMo, 14mm slots with unique tech sink cuts - Integrated Seat Clamp. - CS Length: 20”: 13.25” to 13.5” / 20.75” & 21.25”: 13.5” to 13.75” - Angles: HT: 75°, ST: 71° - Weight: 2.028kg (4.46lb) - Colors: Flat Black, Flat Olive, Lilac, Glow Lime (limited
2/11/2010 2:57 PM
unless your talking about the V3?
if so it's...
Full Magma heat-treated 4130 Sanko CrMo
Fluted & Tapered Seattube
New brake guides & flat truss brace
Top Tube: 20”, 20.75” and 21.25”
New internal gusset improves strength, new color combos
With removable brake hardware/pivots
Head Tube Angle: 75 Degrees
Seat Tube Angle: 71 Degrees
BB Height: 11.75”
Chainstay Length: 13.25” to 13.5”
New shape Mid BB
Internal Headset, drilled for included gyro tabs
Dropouts: Lasercut, 5mm, heat-treated, 4130 CrMo, 14mm slots with unique tech sink cuts
Weight: 2.18kg (lb)
2/11/2010 3:11 PM
ben c wrote:
BB: Height: 11.75”, new shape Mid size BB - Headtube: Int. Headset, included gyro tabs - Toptube: 20”, 20.75” and 21.25” ...more
BUMP ..BEN C YOUR THE MAN!
2/12/2010 2:28 AM
i try smile
2/12/2010 4:09 AM
my good friend has a purple v2 lofi.
he loves it and its a real solid frame
i love fat chicks <3
2/12/2010 7:51 AM
v2 snap like shit
BIKE CHECK!
BEEN HERE SINCE 07 TRUE OG
if you’re pegs ain’t steel, you ain’t real
refs- way to many just ask around
FLICKR
CRAZY MAAZY
2/12/2010 8:46 AM
Also, if you couldn't find the geometry, you could measure some things to find out some basics.
top tube-measure from center of head tube to center of seat tube along top tube
Rear end-Measure from center of BB to center of dropout along chain stays (you can also go to front and back of dropout for a range)
Standover height-Measure from center off BB to center of top tube along the seat tube.
(This might help some younger dudes who want to know their frame geo and cannot find it)
