I am wanting to get one, and wanted to know if anyone has any feedback about it. I ride street and park, and like to grind. I would get the hub guard with it. Thanks
http://www.wethepeoplebmx.de/hardgoods/hubs/supreme-cassette
Has 12mm bolts.. im still not.understanding this..
HardBMX_Tim wrote:Has 12mm bolts.. im still not.understanding this..
Same here. Wtf.
I've had the original supreme cassette since 08'. Get that shit. Mine has only skipped once and my buddies brand new profile hub skipped twice in one day at the trails. German engineering at its finest. As far as the new female version, the 12 mm bolts have a 14mm collar right near the bolt head. Better than most rear female hubs that use 10mm with a 14mm cone washer. Wtp uses 7000 series aluminum which makes the flanges hold up better to grinds than that profile 6000 series butter metal. That's what's up fools!
I'm not very heavy and I like to think i ride fairly smooth. I don't do super big drops either. What would you suggest I get if not that. I rode an animal javelin for almost two years and never had any probs and that axel was hallow a shit.
All I can say is my friend had the 2008 version, never had a problem with it, sold it to a friend and he ended up snapping the axle in like mid-late 2010.. so 2 years in and he snapped the axle.
Butttt, the hub you're talking about is female, so you shouldn't have to worry about that all. and if you do, it'd only be the bolt snapping.
12mm but its for 14mm drop outs makes so much sense
I would not get that haha
Testimony and apologies
instagram
old edit
Stronger than 10mm what's to understand.
Why not just go 14mm, instead of making an entirely new axle size.
brianoob wrote:Stronger than 10mm what's to understand.
HardBMX_Tim wrote:Why not just go 14mm, instead of making an entirely new axle size.
The axle is 14mm, the bolt is 12mm...
I think it's dumb they brought in 12mm. But as long as they keep the 12mm bolts with a 14mm area near the bolt head area for the rear, it should be fine. Just seems unnecessary.
Interesting. I feel like the center axle will be too thin and may be prone to cracking now...
My suggestion would be a Cult Match personally.
And for some reason when I posted originally, I thought they offered both axel styles FA and MA. Not so hot on the female, and I'm am not sure either if the bigger bolt without a bigger axel would be stronger or weaker.
Shadow BTR
14mm female
Crisp sound
Great engagement (identical to Primo Mix)
Pressfit chromoly guards
Bomb proof as fuck!
Got a gsport ratchet and its solid but the simian rear is coming out early next year if you want to wait
a Swedish Lie wrote:And for some reason when I posted originally, I thought they offered both axel styles FA and MA. Not so hot on the female, and ...more
They made the bolt a bit slimmer so that the axle can be a tad thicker. Like I said you can go with a FA 10mm bolt and break the bolt or a hub with a 14mm bolt and break the axle. It seems like a perfect trade off to me for those that NEED female axles for some reason. I run male front and back. Old school but my hubs are super smooth so why change. The 12 mm bolt has a 14mm washer to fit your dropouts, for those that don't understand.
HardBMX_Tim wrote:Interesting. I feel like the center axle will be too thin and may be prone to cracking now...
I'm pretty sure it has a 17mm inner axle... but looking at their website it says it has a 14mm axle. If the latter is true, that's fucking stupid especially with 12mm bolts. That's practically no material there.
brianoob wrote:The axle is 14mm, the bolt is 12mm...
Xxohioanxx wrote:I'm pretty sure it has a 17mm inner axle... but looking at their website it says it has a 14mm axle. If the latter is true, ...more
If its 17 then why not 14mm bolts? Lol
