Want 28 9 gearing but will have to space sprocket
1/12/2016 7:47 AM
Need help i have a wtp trust 2013 and want 28 9 gearing but looks like sprocket will hit chainstay if i space the sprocket my chain will b out of line surely?? Any ideas anyone
1/12/2016 8:25 AM
Try it and find out, it might not need spacing, or the spacing night not make your chainline too far out.
1/12/2016 9:01 AM
Never rode a frame that couldn't fit 28, although I've had one that wouldn't fit 29. 28t is a pretty common size and should work with most frames
1/12/2016 9:01 AM
Measure your clearance and compare decide if a 28t will fit based on the measurements from this informative thread.
http://www.vitalbmx.com/forums/How-To,25/Sprocket-Size-different-25t-amp-28t,1278684
1/12/2016 9:25 PM
Edited Date/Time: 1/12/2016 9:25 PM
I thought the same thing on my Tall Boy frame running a Shadow Align sprocket, but ended up having a couple mm's of clearance.
Are you using a sprocket that slams to the bottom bracket ( doesn't use a driver side cone spacer) ?
1/13/2016 12:22 PM
I have a wtp trust from 2008 and i run a 28t sprocket. i have some space left but not much.
1/13/2016 12:32 PM
Here you can see the gap (and some dirt whistling still have to clean it so please don't mind) as you can see it isn't much but it works.
1/13/2016 12:36 PM
Back in the day we would take a ball pein hammer and put a dent in the tube to give us extra room. Works perfect.
Da Laird
unfuckwithable ill
1/13/2016 3:29 PM
this
ride bikes, have fun
STRAIGHT OUTTA STRAYA
