Do I need that little pin washer that connects to the forks and keeps your front wheel in place
Yes keep that washer In between your fork dropout and axle bolt , it spreads pressure better amongst the dropout then a bolt will
If it's these, then you can take them out. But leave them on if there's no other washer there. You need a washer in between the axle bolt/nut and fork dropout. Or if you have pegs you can substitute that for a washer.
Ok thanks. Also, I stripped my seat post clamp bolt and I want to get a new one. On dans there is only integrated seat post bolts. Can I just get that for a normal seat post clamp or will I need to just get a new clamp
Seeing as seat clamps tend to be made from aluminum and the bolt CrMO its safe to say you need a new clamp as you have probably striped the clamp.and the bolt will be fine. Just simply because aluminium is soft as hell compared to steel. Get a new clamp they don't cost much
