Weird crash, possibly faulty hub?
6/17/2014 3:08 PM
I was riding down the street, all of a sudden my bike acted like my chain broke, but it didn't, and I ended up over the bars. I feel like something in my hub could have possibly given out, although afterwards it rode fine.
6/17/2014 3:20 PM
It probably skipped. It happens
6/17/2014 3:28 PM
ouch.. yeah sometimes pedal tension turns to nothing, it's either snapping that chain or the pawls in your driver not engaging. Your chain's good so yeah it's probably time to clean out that driver, you get enough crud in there it'll cause the pawls' springs to not engage it properly. Hope it wasn't too ugly, i ate it real bad going over the bars like that (popped chain for me tho) and was in ugly shape for a bit.
6/17/2014 10:16 PM
Driver probably skipped. You pedaled and the pawl (s) failed to pop up and engage the ratchet ring, so your cranks spun freely forward with no tension.
6/17/2014 10:33 PM
adfkje wrote:
ouch.. yeah sometimes pedal tension turns to nothing, it's either snapping that chain or the pawls in your driver not ...more
All I got was a pretty nasty road rash on my leg. Haha
6/17/2014 10:34 PM
HardBMX_Tim wrote:
Driver probably skipped. You pedaled and the pawl (s) failed to pop up and engage the ratchet ring, so your cranks spun freely ...more
Yeah, I took apart the hub, someone put thick grease on the pawls, making them not engage right.
6/17/2014 10:37 PM
don't remove all the grease, just take a rag/towel and wipe some out of there. Unless it's super thick grease then just remove all that & put in some regular grease
6/18/2014 9:48 AM
sundaybmxRR wrote:
don't remove all the grease, just take a rag/towel and wipe some out of there. Unless it's super thick grease then just remove ...more
if it's just a regular cassette hub then it's not necessary (or even advisable) to put any oil/grease whatsoever, unless you're trying to dampen the sound. They run fantastic dry and don't require lube unless you're damping it, and damping it automatically increases likelihood of slips. If you don't mind or like loud drivers then run those pawls dry!
6/18/2014 9:59 AM
adfkje wrote:
if it's just a regular cassette hub then it's not necessary (or even advisable) to put any oil/grease whatsoever, unless ...more
I kept the grease on the teeth, just took it off the pawls.
6/18/2014 10:47 AM
and be damn careful wiping it, those pawl springs will launch themselves out and get lost lol
6/18/2014 11:01 AM
It's a wrap around spring hub. From the Cinema 333 complete rear wheel.
6/18/2014 12:48 PM
Thin oil, the same as you would use in brake cables is the best for hubs engagement parts.
6/18/2014 1:12 PM
That might be the dumbest post I've seen in awhile.
Without any type of lube in there, your internals can & will easily be chewed up.
Not to mention spin like shit.
6/18/2014 4:55 PM
Without any type ...more
Hahbahhahaa
This. I was just laughing my ass off at the thought of him working in a bike shop and telling all the kids this so they will have to come back after a month and replace the pawls. hhahahahaha
Seriously though you need grease....haven't you ever seen the movie
6/18/2014 7:58 PM
to each their own, i guess. I don't work with anyone's bicycle excepting my own. This article is more my line of thinking, for anyone who's interested: http://www.profileracing.com/2012/03/q-and-a-do-i-need-to-grease-my-profile-cassette-hub-driver/
unsure which model, but my United came w/ Cinema wheels and i really like them smile
6/18/2014 8:17 PM
adfkje wrote:
to each their own, i guess. I don't work with anyone's bicycle excepting my own. This article is more my line of thinking, for ...more
Finer lubes are one thing, I use them as well, but not having ANY grease in the hub is retarded.
Anyone on this forum will tell you that.
