Weird wheel noise
3/14/2017 3:15 PM
My front wheel has been making some weird noise on impact. Ive tried tightening the cone washers, nothing.
The fork is good, and it makes the sound even when its off the bike.
Here is the sound recording(of me hitting the wheel on a wall) -
https://clyp.it/ke4ux01k
Wake up, ride, have fun, repeat.
3/14/2017 3:39 PM
Check that the spokes are tight, check for cracks in the rim, check for play in the bearings and check if the axle is broken.
3/14/2017 3:49 PM
Quick yeah that should fix it, if it doesn't then spray some wd 40 between your huh bearing and it should be good to rip
3/14/2017 3:53 PM
Edited Date/Time: 3/14/2017 3:54 PM
NO. DO NOT DO THIS. WD-40 REMOVES GREASE.
Sealed bearings need a wipe down, and typically just replacement.
Spokes are probably loose, check those, make sure everything is properly tight, WIPE DOWN WITH A RAG. Check your bars, headset, stem and everything else on your whole bike. I've seen kids who thought their front wheel had issues, turned out to be a loose chain hitting the frame.
Failing that, take it over to a shop.
3/14/2017 4:11 PM
What kind of an idiot puts WD-40 in their bearings?!? It's a degreaser, it destroys any grease in there and makes your shit wear out and break faster! It should never go near a bike with perhaps the exception of putting grips on.
3/14/2017 4:34 PM
p1p1092 wrote:
What kind of an idiot puts WD-40 in their bearings?!? It's a degreaser, it destroys any grease in there and makes your shit ...more
I wouldn't even use it for that.
If I was overhauling bearings or cleaning the inside of my coaster I might use it for CLEANING ONLY, then when fully dry I would regrease everything.
3/14/2017 6:16 PM
Edited Date/Time: 3/14/2017 6:17 PM
Generally, you never want WD-40 near ANY part of your bike. Only use it for stuff like removing sticker residues and such things.
3/14/2017 10:54 PM
Sounds a bit like spokes, depends how you're hitting it against the wall. If it's got sealed bearings and the bearings are worn, tightening the cones won't do anything. It could also be a worn shell, the noise could be from the bearings/axle moving inside the shell. You can fix that with coke can shims
3/15/2017 2:13 AM
Sounds a bit like spokes, depends how you're hitting it against the wall. If it's got sealed bearings and the bearings are ...more
The sound comes from any impact
3/15/2017 3:53 AM
Then it's either spokes or worn bearings. When it's on the bike is there any side to side play? If there isn't a noticeable wobble, try putting the bike upside-down, stand on the bars and push the wheel side to side with more force. Or just take your axle out and see how rough the bearings feel
