What brakes can be run with 2.35 tires
9/9/2016 7:16 AM
I run my backend as short as possible and started having my brake arms rub when I changed my 2.2 tire to a 2.35. I was using some old dia compe brakes. Anyone have info on What brakes are compatible with large rear tires?
9/9/2016 7:25 AM
I've never really looked into it. But couldn't you add a spacer to the post between the pad and brake arm? So the arms would be further away from the tyre but the pad would be the same distance
9/9/2016 10:26 AM
Yup. Back when I ran a 2.35" tire, I did exactly this. Running an Odyssey EVO II setup, but it worked perfectly.
Instagram: @scootereyn
9/9/2016 5:40 PM
Yeah? I don't really know stuff about brakes but I'm guessing if Evos have done the trick before they'll do it again. At this point a spacer wouldn't help cuz part of the arm runs in any position. Like even if the brake isn't squeezed the top part of the arm is still rubbing. that's why I figure it must be the kind of brakes im using. Tx for the input guys.
9/9/2016 7:07 PM
run a longer back end
ride bikes, have fun
STRAIGHT OUTTA STRAYA
