What is wrong with my cranks?
10/6/2016 4:24 PM
The bolt loosens like every day leaving them loose as hell, and when I tightened them yesterday I went to crankflip and they spun fine until one spot and completely stopped. And once in a while they will skip a ton. My chain is really looose for some reason so maybe that is the skipping problem. What should I do?
10/6/2016 7:32 PM
Buy a new bike.
Your back wheel sounds fucked.
10/6/2016 10:39 PM
adamnmexican wrote:
Buy a new bike.
nah my back wheel is fine, its my cranks they keep loosening sad and there is a spot where they stop on crankflips, maybe i should grease my spindle and tighten my chain?
10/6/2016 11:18 PM
take everything apart(cranks bb and hub) clean it, check if anythings fucked up and grease it
10/7/2016 1:00 AM
Buy new cranks. But check your driver and bb too. Your cranks loosening isn't the reason they stop spinning when you do crank flips. Your chain being loose could be the reason it skips, but you could also have a worn chain/driver/sprocket.
Crank bolts usually only loosen themselves if something is bent, or the splines are worn.
